Power Brake kit
Old Jun 14, 2001 | 03:19 PM
kchristopher's Avatar
kchristopher
Power Brake kit
I have a 1958 ford pickup, that I am putting power brakes on. I ordered a kit for my truck from No Limit Engineering. I just got it yesterday. I decided to play with it a little bit as I have never worked on a vacuum brke system. With the unit not installed and no fluid in the unit (master cylinder and vacuum booster) I tried to blow into the vacuum line on the vaccum booster. I was not able to blow into it, but when I tried to suck as much air out as possible, I could hear slight air comming in at the bottom of the master cylinder where it bolts to the vacuum booster. There is a place formed at this spot that looks like it probably should have this. I am able to build up a little vacuum, but it does not last long, and my method is not very scientific. I was wondering if there is a good way to test the vacuum booster with it out of the vehicle. I called the vendor's support but they did not know if was supposed to or not, local mechanics and web searches pull back different opinions. Please help, I really do not have time send this back, and would rather take the loss and fix it here if possible, if I even have a problem.
Thanks
klc
Old Jun 14, 2001 | 07:53 PM
Franklin2's Avatar
Franklin2
Power Brake kit
You could hook a vacuum line to one of your other cars and see what happened but I don't know what you expect. It's not going to act right if you don't have fluid in the master cylinder and something for the master cylinder to develop pressure against.
Old Jun 15, 2001 | 09:20 AM
kchristopher
Power Brake kit
Actually, I am not trying to test the master cylinder. I am trying to test the Vacuum booster. As far as what I expect, I am not clear as to what to expect, that is why I posted. If this is not the forum for such a question, you have my apologies.
I guess the short question would be:
How do I test a vacuum booster that is not in the truck? How long should I expect it to hold the vacuum?
Old Jun 17, 2001 | 03:56 PM
tkbowman's Avatar
tkbowman
Power Brake kit
I would probably hook a vacuum pump up to the booster although I've never tried to test one out of a vehicle.
Tim in Burien
'56 F100 (now big back window ; soon to be with a Mustang II F/E)
tkbowman@qwest.net
Old Jun 19, 2001 | 04:57 PM
Determan's Avatar
Determan
Power Brake kit
