Multifunction Switch
Old Dec 26, 2006 | 01:23 PM
Craze's Avatar
Craze
Question Multifunction Switch
Looks like I am going to have to change the Multifunction Switch (AKA turn signal switch). So it appears that I have to pull the steering wheel to do this. How do I go about accomplishing that?
Old Dec 26, 2006 | 01:26 PM
bkcowboss's Avatar
bkcowboss
I changed the switch without pulling the steering wheel it is not difficult on my 97 cant remember the exact steps but not difficult, just curious though, I went barking up the wrong tree and ended up putting the old one back in, why are you changing it?
Old Dec 26, 2006 | 01:34 PM
Craze's Avatar
Craze
I have traced a (once-in-a-while) brake lite malfunction down to there.
Old Dec 26, 2006 | 01:42 PM
bkcowboss's Avatar
bkcowboss
Roger, mine was a blinker malfunction, any way if I remember right I pulled the plastic cover from around the steering column, but may have been only the bottom half there are two torque bolts in there, something like a T21 size unscrewed those unplgged the connector and fanagled it out, a little trick on that part but came pretty easy, then reinstalled. I couldn't get my steering wheel off. Once I got the part off I disassembled it, cleaned the baddly coroded connections reinstalled the old part and it still works 18 months later. Good luck
oh yeah thanks for the part # on the burnt pin link I compile all that info for future reference.
