fluid capacities
Old Dec 26, 2006 | 11:43 AM
kilog55's Avatar
kilog55
fluid capacities
need to change out my dif fluids front and rear as well as transfer case and tranny
i have the
rear D60
front D44
4speed manual T18?
and transfer case i am unsure if i take a pic could you tell? might be a np203?
1979 f250 ranger is the truck vin is F26SNEG4150 doesnt help i know and i do not have a data tag
Old Dec 26, 2006 | 08:12 PM
plowpusher's Avatar
plowpusher
from the 1979 ford truck owners manual:front axle f250 4x4 dana 44; 5.6 pints,rear axle dana 60 f250/350 4x4; 6.0 pints,4 speed (warner T-18); 7.0 pints,4 wheel drive transfercase,two speed part time; 4.0 pints,full time ;9.0 pints good luck!
Old Dec 26, 2006 | 11:05 PM
kilog55's Avatar
kilog55
part time is 4lo n 2hi 4hi correct? also what weights would i use? any particular brands like amsoil, royal purple, etc syn. or dino?
so i would need
12 quarts for front and rear
7 quarts for tranny
and 2 quarts for trans case if my math is correct.
Old Dec 27, 2006 | 11:07 PM
plowpusher's Avatar
plowpusher
I use amzoil synthetic gear lube in my tranny,tranfercase,and both diffs better cling factor than petroleumn based and doesn't get stiff in cold weather and less friction
