370 replacement or performance options
Old Dec 26, 2006 | 07:24 AM
Nedcampion's Avatar
Nedcampion
I have a 1979 4x4 F600 with a 370 2v The truck has 7.17 gear ratio with a 5spd. what would a good replacement motor capable of towing my 9 ton Log skidder? or could i hop up the 370,it only has 12,000 miles on it Thanks and Merry Christmas!
Old Dec 26, 2006 | 09:14 AM
guss36's Avatar
guss36
put 4bbl on it.not alot you can do.put a 780 holly with no gov.the factory gov is set around 3500rpm.turn no more than 4500rpm if you do you will fill it falling off pretty fast in hp.
Old Dec 30, 2006 | 11:35 AM
2Wise4aGM's Avatar
2Wise4aGM
Personally I would swap in and industrial 429 4v. it is a bolt in swap, and a definate performance improvement.
Old Dec 30, 2006 | 08:03 PM
Nedcampion's Avatar
Nedcampion
That is what i was considering,a 429 4V. I think i will try the 4V option with the 370 while i look for a 429 4V. Any ideas where i can get a up and running industrial 429 4V in the north east? How can i tell if it is a industrial block and what are the HP.and torque #'s? Also what intake does the 370 take is it the same as the 429? Than i could swap it over if i find a 429 2V. Thanks for your ideas
Old Dec 30, 2006 | 09:47 PM
darrin1999's Avatar
darrin1999
a 460 will bolt up to the tranny, or if youre after more power than that you can stroke it... the crank snout is smaller, but i dont think thatll be an issue unless you try to reuse the 370 block
