Help with a bad ground????
Old Dec 25, 2006 | 09:41 PM
is300wrx's Avatar
is300wrx
Ok here is my problem. Whenever my screen is playing a movie or when it gets activated by my back up camera, there is an interferance and it is visible because there are horizontal lines that pass on my Panasonic head unit screen. From what I heard from my friends, it is a bad ground and that I need to check my wiring....Where should I look??? My buddy took a quick look at it last night before heading off to his xmas party and he moved the RCA cables around and the screen went nuts....Please help
Old Dec 26, 2006 | 06:44 AM
96f150's Avatar
96f150
Is the engine running when this happens? Try separating the power cables off to one side and the audio cables off the the other side. Try to keep them separate, as you will pick up inherent noise when they are run side by side.
Old Dec 26, 2006 | 10:08 AM
is300wrx's Avatar
is300wrx
yea, the engine is running when this happens, when I shut the truck off the lines dissappear. Thanks buddy
Old Dec 28, 2006 | 09:11 AM
resopkr's Avatar
resopkr
You might also try some snap-on Ferrite cores around those leads. They will help filter out some of the noise. You can get them at Radio Shack. They open in half. I would open the core and make a single wrap of the lead around one half of the core and then snap it shut. These cores are used alot to filter out RFI. Ever wonder what that round cylinder is on the power cable going into your computer? Its a Ferrite core.
Old Dec 28, 2006 | 09:16 AM
is300wrx's Avatar
is300wrx
my buddy fixed the problem two nights ago. Took the dash apart and rerouted the wires so there wasnt any interference between the two sets. Now its back to normal. Only thing that bothers me is that its been pretty cold out lately and the plastics on this truck seems to shrink in the cold and it makes all these new noises that I am not familiar with!!
Old Dec 28, 2006 | 09:17 AM
Erk469's Avatar
Erk469
You might want to think about adding another engine to chassis ground, I had the same problem with engine noise, come through my head unit and lines on my monitor..I used a 2 guage grounding wire..It worked great.
