Sponsored by: Real Truck
F350 cab light Install
Old Dec 25, 2006 | 06:27 PM
savage2211's Avatar
savage2211
Is the 1999 F350 prewired for cab lights? If so where can I find the wire hook up? Thanks
Old Dec 25, 2006 | 08:06 PM
savage2211's Avatar
savage2211
I know I am not the only one to add cablight to there truck.....Please help
Old Dec 25, 2006 | 09:56 PM
RACERX7775's Avatar
RACERX7775
proably not wired up for it but they aren'r really that hard to do the job. the biggest thing is getting the lights straight and drilling holes in the roof. you can do the wiring yourself to save some money. just buy the lights and the mounting nuts then run the wires to power and ground. its a cheaper way but the correct way is to buy the harness that goes from the pass kick panel to the lights from ford and do it that way. there is someone who posted exact measurements on here but you will have to find that. good luck. measure several times, drill carefully. i would cover the roof with tape, mark the holes, place the lights on the roof, look back at them, then drill through the tape to protect the paint from chipping. oh, drop the headliner first!!!!!!!
Old Dec 26, 2006 | 09:00 AM
Deluxe05's Avatar
Deluxe05
Yeah, chances are that they are not pre-wired.
Hit up one of the site supporters or your local Ford dealership. The wiring harness & lights are relatively inexpensive. If you do a search here on the forums with something similar to "cab clearance lights", I'm pretty sure you will find the part numbers....if you have any issues finding them somewhere else.
And you can find installation instructions here: http://www.emotoman.com/f250/lights/f250lights.htm
Old Dec 28, 2006 | 07:10 AM
glruff's Avatar
glruff
FTE Leadership Emeritus
Welcome to FTE. You will can find an answer to any question you post. Best resource on the web is FTE.
How about joining the New Delaware Chapter which is starting to get rolling, rolling, rolling. Click the link:
New Delaware Chapter Forming!
