1978 - 1996 Big Bronco
torque converters/93' 4EOD
Old Dec 25, 2006 | 11:21 AM
RA81222's Avatar
RA81222
Do these have a drain bolt on them?If they do how do you rotate it to get at it?
Old Dec 27, 2006 | 05:21 AM
muckypaws's Avatar
muckypaws
my 92 does have if thats a help. Can you not crank the engine over to rotate it. Remove the HT lead off the coil to prevent it starting up.
Simon
Old Jan 14, 2007 | 11:57 PM
benshere's Avatar
benshere
drain plug
My 93 5.8/E4OD does have a plug. Did a converter change not too long ago. I used a converter supposedly for an E350 ambulance (dont ask why I did that!). This one has "LUK" clutches. Put it in Neutral an use a big flatblade screwdrive through the inspection plate or large hole in bottom of housing and pry on the flywheel teeth. Do Not screw up the teeth on the flywheel. If you have a helper, do the key trick (disconnect the coil leed) until you get the plug close.
Old Jan 15, 2007 | 09:38 AM
slickerthanyou's Avatar
slickerthanyou
A screw driver works great! Been there done that!
