ppv question on axle swap
Old Dec 25, 2006 | 06:22 AM
fordsrgrt's Avatar
fordsrgrt
going to swap out the closed knuckle axle in my 74 250 for an axle from a early 77 highboy.,so will i need to get a new ppv for the brakes or will the old one on the truck be sufficient,and will master cylinder need to be swapped out or not thanks
Old Dec 25, 2006 | 08:49 AM
plowpusher's Avatar
plowpusher
I did the same with my 75 (drum to disc). I used the ppv off the disc truck, found that the booster from the drum truck would not fit the master for the disc truck and ended up using a booster from a pre 77 3/4 ton 2wd with dics breaks that didn't have the bellcrank and the master off the same 2wd. A good way to find what you need for a booster and master is to look at the parts book for a 76 3/4 ton 4wd they basicly used the same parts
as I described.If you need more info you could pm me look in my public profile
Old Dec 25, 2006 | 10:05 AM
fordsrgrt's Avatar
fordsrgrt
thanks kinda thought they wouldnt work.just have the axle, no truck to look at ,guess i will need to but a new ppv too, as well as m.c. and power booster
Old Dec 25, 2006 | 11:43 AM
Mil1ion's Avatar
Mil1ion
You can also look up the correct application on this site as well.
http://www.precisionrebuilders.com/p...ogPHB-0398.pdf
Old Dec 27, 2006 | 12:49 PM
fordsrgrt's Avatar
fordsrgrt
does anyone know if you can buy an oem ppv for that year or do i need to go with an after market one?
Old Dec 27, 2006 | 01:43 PM
Mil1ion's Avatar
Mil1ion
This is the best price vs quality I can find.
http://www.inlinetube.com/Prop%20Valves/VFL101.htm
The OEM one is long gone from dealerships.
