ford charging problem
Old Dec 24, 2006 | 10:35 AM
tequilaq's Avatar
tequilaq
96 f250 does not charge when first start running. takes about 45 minutes before starts to charge. checked alternator-ok. could this be the ecm? if so where is it located? or what else to look for?
Old Dec 24, 2006 | 06:03 PM
kell104's Avatar
kell104
Could it be charging but your guage is not working at first? Have you actually checked voltage at battery? 45 min. seems like a long time for it to run without any charging at all, I would think your bat. would go dead before that.
Old Dec 25, 2006 | 09:00 AM
tequilaq's Avatar
tequilaq
have checked battery= OK. have checked guage =ok. i have to charge battery with charger. let trk run for awhile then starts to charge
Old Dec 26, 2006 | 12:58 PM
albung's Avatar
albung
regulater??????
Old Dec 26, 2006 | 01:03 PM
steveo88's Avatar
steveo88
dual batts?
Old Dec 27, 2006 | 12:15 AM
bustech81's Avatar
bustech81
what voltage do you have when the truck first starts? does it slowly increase?You say it takes 45 min to start charging, at the 45 minute mark does the voltage all of sudden jump from 12.6 to 14.6. more info please?
Old Dec 30, 2006 | 08:14 AM
tequilaq's Avatar
tequilaq
Smile f250 no charging
changed alternator solved problem
