hope your running when parked project is better than mine. a got a 63 f 250 4wd with a 352 that was running when parked.i took it home put a fuel pump,a carb kit,and spark plugs to get it running then i had to replace the collapsed lifter then the carb went all screwy had to tear it back down. got it running put in shop built exhaust fired up yesterday bent 3 push rod fixed that carb screwed up agian fix that. take it out this morning and discover front axle is missing all the teeth of ring gear. great more parts. seems like every time i start it something else breaks. good luck on your project.
me and my dad decided evil elves are breaking into our shop at night and messing with my truck. it gets a little agrivating though i fix one thing and something else breaks or leaks or starts knocking.
