disc brake help
Old Dec 23, 2006 | 06:39 PM
woody367's Avatar
woody367
disc brake help
I am looking for a front disc brake conversion kit for a 1950 Ford F. Anyone know a good place? Thanks
Old Dec 23, 2006 | 07:20 PM
TBucketJack's Avatar
TBucketJack
Speedway Motors just started handling disc conversions but only for the smaller ford or chevy bolt patterns. ie: 4 1/2" or 4 3/4". CPP, ECI, MPB, along with Vintage Ford Sacramento, and others have the kits for 5 1/2" bolt pattern. Good Luck
Old Dec 24, 2006 | 06:28 AM
GreatNorthWoods's Avatar
GreatNorthWoods
Classic Performance Parts (CPP) runs an Ebay auction on a continuing basis for a bolt-on disc brake kit for 48-56 trucks for $89 in a variety of bolt patterns. See current auction number 300061941146.
Old Dec 24, 2006 | 06:59 AM
g84t8f1's Avatar
g84t8f1
I got my kit from Vintage Sacramento.That was 2 years ago.cost about $350.00 + shipping.That was a complete bolt on kit.I like mine.Good luck.
ART
Old Dec 24, 2006 | 09:11 AM
woody367's Avatar
woody367
The truck was bought in the middle of a restoration. We pulled the engine apart and founf the cylinders and crank scored. So we know it needs work.
Old Dec 24, 2006 | 12:12 PM
Steve's Avatar
Steve
I want to convert to disk brakes too. I have a '56 long bed and carry a 1,500 lb Alaskan camper. Last summer I was descending the east side of Sonora pass in California, (this is a really steep road) and even though I stayed in 1st (3-speed manual), by the time I was near the bottom, I literally would not have been able to come to a complete stop- only control the speed. Fortunately, after the road leveled out we were OK, but I don't want to go through that again.
I have looked at the mid-fifty conversion kit. They carry a kit for 5 1/2 bolt centers that includes the power booster (supposedly pre-valved ?) for $795. I am assuming one needs the power booster when going to disks. Any body use this one?
Old Dec 24, 2006 | 12:46 PM
imlowr2's Avatar
imlowr2
I used the CPP kit on my 56. Easy to install and I have had no problems. Check out my gallery under Brake Conversion for pics.
Old Dec 24, 2006 | 12:59 PM
TBucketJack
Hey Steve, I believe manual discs are the way to go for most applications. Most of the guys I've talked to said the power conversions are very touchy. But that was in 1/2 trucks. There is a wealth of knowledge on this site. Good Luck
Old Dec 24, 2006 | 02:43 PM
Steve's Avatar
Steve
I guess non-power would be my preference if there was enough stopping power. If I go non-power, I guess it would still be mandatory to change the master cylinder to a more modern dual design. Do the non-power, dual master cylinders use a smaller bore than the power models? Is it necessary to change the rear wheel cylinders, or does an adjustable proportioning valve do the trick?
Old Dec 24, 2006 | 07:33 PM
TBucketJack
A dual master cylinder is a must for safety. I'm not the brake expert but a 1" bore should be the largest used and a proportioning valve in the rear line to balance your system. Power brake M/C have larger bores.
Old Dec 24, 2006 | 09:31 PM
428cobrajet's Avatar
428cobrajet
I am going to convert my 51 to front disc as well. If I buy one of these kits with out rotors and bearings what year and make rotors and bearings will mount on my spindle?(small ford pattern)
Old Dec 25, 2006 | 08:04 AM
GreatNorthWoods
Kits vary according to manufacturer but most come with a bearing adapter that "slides" over the spindle (and I use that word loosely because it's a very tight fit). The bearing adapter that comes with the kit depends on your using certain rotors and bearings which are specified for the kit. Usually, GM rotors if you want 5 on 4.75 pattern, Ford truck if you want 5x5.5 and Ford passenger car if you want 5x4.5 are the rotors specified..
Old Dec 26, 2006 | 01:32 AM
51ford fan's Avatar
51ford fan
Check out my gallery with the T-5 trans install, in there are pictures of the 76 Buick Estate Wagon manual Master cylinder I installed. It was for the same car the calipers fit I left the rear wheel cylinders the stock size. Sense that time I have read where the early Mustang M/C units are a direct bolt in. But for me this manual setup works great, I feel with all the leverage you get with the lenght of the stock brake pedal arm I would kill myself with power. I have no problem locking them up in fact this truck has better stopping power than any old car/truck I have ever owned. And over the last 45 years I have owned quite a few.
