Dual Shock Kit
Old Dec 23, 2006 | 04:06 PM
King Ranch Glenn's Avatar
King Ranch Glenn
Dual Shock Kit
Anyone know who makes a dual shock kit for a 2004 4WD? I can only find kits for 2003 & earlier.
Old Dec 23, 2006 | 04:26 PM
Ferguson65's Avatar
Ferguson65
Are you talking front or rear? Fronts ain't going to happen as this truck uses struts up front, unless you do something totally one off and custom like a solid axle swap. As to rears, with the shocks mounted outside the springs, it wouldn't be easy or inxepensive either. Dual shocks are more for looks than function anyway, you really won't gain anything except a harsher ride when you add more shocks. Why are you lloking for dual shocks anyway? There may be another viable solution if you have a ride issue you would like to change.
Old Dec 23, 2006 | 04:37 PM
King Ranch Glenn
These are for the front. My son-in-law just put a 6" lift on and he is looking for a front dual shock kit. Overall, he is pleased with the ride, but he wants the front a little stiffer. A custom set up is not going to happen. Any ideas?
Old Dec 23, 2006 | 08:30 PM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
get another truck. you can't get the dual setup in this model like you could in the older F series. unfortunately just cannot be done using stock front suspension
might want to look at upgrading the front coil over to some bilstiens (spelling?)
Old Dec 25, 2006 | 10:17 AM
Ferguson65's Avatar
Ferguson65
The bilsteins are an idea, but they may not be available to work the the 6 inch lift. As far as other options, I don't know any. You just can't do a whole lot with struts, unless you get rid of them, and you (he) don't want to do that. You might be able to contact the suspension maufacturer to see if they have a strut with a stiffer valving, but thats about it.
Old Dec 25, 2006 | 04:52 PM
Colt4Life's Avatar
Colt4Life
What manufacturer is the lift from? Some use the factory coils to keep the ride a little more pleasent, he may want to look for stiffer/heavier coils. Skyjacker replaces the factory coils but i'm not sure how they compare (stiffness wise).
rock2610d
Aug 7, 2015 06:10 PM
wit2003
Jun 17, 2015 03:11 PM
79F250isalive!
Mar 1, 2015 07:32 PM
jaltman1984
Mar 2, 2014 01:11 PM
Ford1TonsRock
Jun 1, 2004 02:49 PM
