Valve Stem Seals
Old Dec 23, 2006 | 03:13 PM
DilutedImage's Avatar
DilutedImage
Question Valve Stem Seals
I'm replacing my valve stem seals, and ran into a bit of a problem. The FelPro seals that I picked up from AutoZone are different sizes for the intake and exhaust, but the factory seals that are on my truck are all the same size. Looking at various sites (AutoZone, Kragen, Napa, etc...), it appears that FelPro has different part numbers for intake and exhaust, while most other manufacturers have the same part number for both. My instict tells me to use the same size that's on the truck, but I can't help but wonder why FelPro makes two different sizes. ... I'm planning to finish this job in about an hour, and any input would be appreciated.
Thanks!
..... 1977 Ford F250, 351M (CA emissions), 4x4, C6 .....
Old Dec 24, 2006 | 05:23 AM
DilutedImage
So I've done some more research, and believe I've found an answer ...
This appears to be an error in FelPro's product line. FelPro has two different part numbers for valve stem seals, one for intake seals and another for exhaust seals. Not only are the part numbers different, but the seals are in fact different also (as would be expected by the different numbers). However, the valve stem seal "kit" that FelPro sells for the 351M contains 16 identical valve stem seals. The seals contained in the kit are the same as those found under the product number for the intake set. The seals contained within the exhaust set are roughly half the height of those found in the intake set or the full "kit", and are not the correct part for the 351M engine. So, if you're planning to replace your valve stem seals with some from FelPro, then be sure to either purchase a full 16 seal kit or two boxes of intake seals.
Take care, God bless, and have a very Merry Christmas.
Old Dec 24, 2006 | 07:58 AM
kilog55's Avatar
kilog55
i got the felpro kit as well for my 400 and i just used the pack of 16 same size ones that came with it. there are only 8 of the shorter ones. and all of mine were the same size on the heads.
Old Dec 24, 2006 | 02:26 PM
DilutedImage
Sorry, you lost me on that one ... Your truck did or didn't have different sized seals for the intake and exhaust?
Old Dec 24, 2006 | 02:33 PM
kilog55's Avatar
kilog55
yeah i got out of control. it had all the same size seals in it for intake and exhaust on the heads the larger ones. the gasket set had both sizes 16 big and 8 small. does it make a difference that i didnt use the smaller ones???
Old Dec 24, 2006 | 03:01 PM
DilutedImage
Okay, that makes sense now .. It confused me because my kit only had 16 tall seals, and zero short ones. Now I'm really curious about those short ones; I assumed it was a mistake, but not if your kit had them. My truck didn't have short seals on it either though, so I don't think they're important. I am curious as to what engines they're for though.
Old Dec 24, 2006 | 03:21 PM
kilog55's Avatar
kilog55
no idea i got my kit from advance auto and it said on the parts list 16 valve stems and near the end it said 8 valve seals. confused the hell outta me but my buddy (a mechanic) said they were for the intake valves but you odnt have to use em. just wondering if he was correct.
he has built a nice 400 and waiting to run his 460 in the 76 shortbed f100/f150 cant remember which it is.
Old Dec 24, 2006 | 10:52 PM
Torque1st's Avatar
Torque1st
Posting Legend
For optimum sealing machine the intake valve guides for Teflon seals in a metal sleeve. Use the long rubber umbrella seals on the exhaust valves.
Old Dec 26, 2006 | 11:19 AM
Purely Ford's Avatar
Purely Ford
In my 351C I had the machine shop install graphite valve stem seals. So far after close to eight years I've had zero problems.
Also, if you run the engine at higher rpms the teflon seals are prone to separation.
Old Dec 26, 2006 | 11:37 AM
badblueoval4life's Avatar
badblueoval4life
i have run teflon seals in my 79 466 bogger truck motor and have had no trouble at all but thats just my opinion.
Old Dec 26, 2006 | 12:37 PM
Torque1st's Avatar
Torque1st
Posting Legend
I ran teflon seals in my FE to 9000 RPM with no problems.
Old Dec 28, 2006 | 11:13 AM
Purely Ford
It isn't possible to accurately compare experiences in the durability of a part used in totally different engines and operating conditions. If you haven't had problems with them it could be because you didn't run the engine at high rpms long or differences in engine specs like valve lift, clearances, etc...
Seeing high rpm engines disassembled that have broken teflon valve stem seals is an attention getter. If the material or design has changed then maybe they will last better now than they did years ago.
Lastly, I have never heard of anyone complaining about the same or similar problems with the graphite valve stem seals in any engine or any operating condition.
Old Dec 28, 2006 | 05:26 PM
Torque1st's Avatar
Torque1st
Posting Legend
The Teflon seals I used were "first generation" parts, back in 1970. I would say that was years ago... The 390 was a high performance engine running ~500HP that ran 7-9K RPMs for hours on end. Gas was cheap back then. The Teflon seals worked well and I would use them again.
Old Dec 31, 2006 | 10:02 AM
Purely Ford
Anyone who has no knowledge of graphite seals and gaskets would do themselves a disservice by not getting familiar with them.
03excab
Modular V8 (4.6L, 5.4L)
Mar 22, 2016 02:11 PM
ZARTT1939
1983 - 2012 Ranger & B-Series
Feb 17, 2016 08:16 PM
couttolenc
Apr 6, 2015 08:48 PM
JoeVR5
Aug 9, 2011 09:07 AM
ladiabla74
Apr 27, 2007 09:55 AM
