driving down the road, flat and level, with a slight load on the motor...
I get this "SSSSHHHHHHHHHH" sound and feel a drag on the engine. it comes and goes every few seconds. at first it sounded like it was coming from the passenger side of the engine compartment, but now I'm not so sure....
it reminds me of ... driving a 4 cylinder gasser on a hot summer day with the AC on, when the compressor kicks on, you can hear it and feel the loss of power in the pedal...
thats the best way I can describe it....
I also noticed when pulling a steep hill at about 60 mph, my check engine light flickers when I'm almost to the point of downshifting to pull the hill. I put a code reader on it but its not throwing any codes.
I checked the boots going to the turbo (orange/blue) for cracks or tears but havent found anything on my first glance inspection.
doesnt matter if the heat/defroster is on or off...
clean airfilter....
re-attached line to waste gate... no change...
It's perfectly normal dude. What is happening is the engine is not up to normal operating temperature, so the sensors trigger the actuation of the Exhaust Backpressure Valve on the outlet of the turbo. It restricts about 95% of exhaust flow, which keeps heat in the engine, to warm it up. More throttle will let it disengage and it will actuate again when the conditions are right.
What is the outside temp when this happens? Until I Unhooked my EBPV it would come off and on up to 10 miles under light throttle when outside temps were close to 32*. Once engine fully warmed up, it would go away.
I've had the truck for a number of years and never noticed it before... I plugged it in and since it is only about 40 degrees today it was already pretty warm and it did it all the way to work, which is about 30 miles....
As pbr man said, check the ebp sensor and tube, it could also be caused by a bad thermosat (coolant not getting hot enough)or a bad Engine Oil Temp sensor. Good luck!
It's the valve that you have to disconnect, unplugging the sensor won't help much. The valve is kind of a PITA to get to as it's on the bottom of the turbo where the exhaust downpipe connects. You would also have to wire the butterfly open, or it will just shut on its own.
Oh, yeah, I stand corrected! Thanks Kris! Most of my 7.3l experience is on Econolines and it's almost impossible to unplug the actuator without major surgery on them so I didn't even think of that.
Probably a bad sensor, making the ECU think that the engine is cold and closing the valve. There's a reason for that SES light to flicker like that.
Unplugging the EBPV is just a band-aid, find and fix the real problem and you'll do better.
