Modular V10 (6.8l)
Spit first plug and heli coil
Old Dec 23, 2006 | 11:45 AM
haarman's Avatar
haarman
First thanks to every one that writes all the great threads. This site convinced me to buy a V-10 and it is the best truck ive ever had and have been more than happy with it until today. When i spit my first plug. It wouldn't relly bother me much except for the fact that the heli coil went with it. I was wondering if there is anything that i can do besides buy a new head. 99 F-250 165000miles
Old Dec 23, 2006 | 03:35 PM
hydro_37's Avatar
hydro_37
This may be an option. http://cgi.ebay.com/ebaymotors/FORD-...QQcmdZViewItem
hope this helps. Tim
Old Dec 23, 2006 | 03:45 PM
captchas's Avatar
captchas
Guest
time sert
no you don't need a new head, http://www.timesert.com/index.html
they have a double over size to make a great and better repair then with a helicoil get the kit and do them all at one time and just double over size that one and any others that may have gotten repaired the wrong way
Old Dec 24, 2006 | 11:59 AM
haarman's Avatar
haarman
thanks alot you guys makes me feal alot better
Old Dec 24, 2006 | 02:38 PM
Mr. G's Avatar
Mr. G
I realize that this plug spitting thing has been beat to death but I was wondering if anyone has ever had a Timesert fail? I have been considering doing all eight just for the piece of mind but not if it can also fail.
Old Dec 24, 2006 | 03:02 PM
ckentling's Avatar
ckentling
I spit a plug at 85K and now have 127k and have not had any issues at all with the timesert for 50k miles
Good luck
Old Dec 24, 2006 | 06:21 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
Having been a visitor to this forum for over 5 years, and a moderator for what, 8 months? I can truthfully say, no one has ever come back and reported a Timesert going bad.
That doesn't mean it hasn't happened!
Just that we've never heard of it. And I think we'd be the first to know, given how much we recommend this to everyone.
Merry Christmas!
Old Dec 24, 2006 | 07:33 PM
LEVEL10's Avatar
LEVEL10
me nether. and over my 42 years in the shop i have never seen any timesert or full torque thread repair fail. what dose fail in spark plugs and really in any alloy part was the heli coil which is fine in a cast iron but still not for spark plugs in that either.
captchas
Old Dec 25, 2006 | 08:51 PM
ToaDisco's Avatar
ToaDisco
Yep, I've probably got close to 15,000-20,000 miles on my timesert repair and all is well. When I was installing it I was confident that the repair was a good one.
Old Dec 25, 2006 | 09:40 PM
commandtoad2's Avatar
commandtoad2
hay haarman, i just bought a full torque kit ($450) and would be willing to let you "rent" it out. and that goes for anybody on this board. i used it once and although it was worth every penny, i'd like to get some of my money back while saving some of you some. say for $50 plus shipping and the cost of the insert @ $10.00 i'll loan it out. of course you will also be responsible if you break any tools in the process. i broke that tiny 1/16" drill bit, but again those things are cheap as well.
Old Jan 11, 2007 | 08:51 PM
ylud's Avatar
ylud
to whom it may concern-please check out www.locknstich.com-they do have a solution.
Old Jan 11, 2007 | 09:09 PM
Mr Incredible's Avatar
Mr Incredible
Did anyone here do their own insert and use that trick of packing the tap with grease to pick up the cuttings? How'd that work out?
I'd be scared to death to do that on the motor! That'd turn a $50 job sour real quick.
Old Jan 12, 2007 | 10:40 AM
ToaDisco's Avatar
ToaDisco
Yep, I did just like they mentioned with packing the flutes of the tap with grease to catch the shavings. It seemed to catch most if not all of the shavings, then I ran a tube connected to a shop vac thru the plug hole and vacuumed anything that got through. I've got close to 20,000 miles on the repair and all is well, so it seems to be working fine!
Old Jan 12, 2007 | 12:07 PM
ylud's Avatar
ylud
I need to correct my referal earlier the correct address is www.locknstitch.com-sorry for the confusion.
Old Apr 7, 2008 | 10:57 PM
natethegreat_2005's Avatar
natethegreat_2005
catching the shavings
i just put a time sert on ... you guessed it the rear plug on the passenger side. # 3 so i've heard. If you are going to tap the head, you need to make sure that the cylinder is all of the way up. put a screwdriver down on top of the cylinder and get someone to bump the ignition until it is all the way up.
Then i did three things.
1: use a magnetic pen to pull out shavings
2: use an air compressor to blow out shavings
3: use a shop vac to suck out shavings.
I did each of them twice until i felt like that was pretty much it. be sure and make sure that the cylinder is all of the way up though because if it is down and you blow int it, you are sending the shavings further in to the engine.
