ulsd
Old Dec 23, 2006 | 01:14 AM
repou's Avatar
repou
ulsd
Has there been any bad effects from this fuel? Do I need to run additives?
Old Dec 23, 2006 | 06:17 AM
ponch37300's Avatar
ponch37300
One thing that i noticed from everyone on this forum is that when the switch was made alot of people had fuel leaks around the o-rings on the fuel bowl. From the reading i have done the fuel suppliers are supposed to put enough lubricants in to make it safe to use in our trucks. I had been running diesel kleen in every tank and continue to do so. It helps lubricate and keeps from gelling and also has a bunch of other benefits.
Old Dec 23, 2006 | 09:59 AM
wolfe1104's Avatar
wolfe1104
Iv also been running diesel kleen in every tank.
The only bad effect Iv seen personaly is a drop in fuel milage.
Old Dec 23, 2006 | 04:57 PM
Zephyr's Avatar
Zephyr
I personaly have not had any problems relating to the new fuel, BUT there have been alot of fuel leaks that seem to have appeared since the new fuel came out .
Old Dec 23, 2006 | 08:05 PM
Stewart_H's Avatar
Stewart_H
I've been reading a lot about the leaks too, so I picked up a pack of 10 PTFE O-rings from McMaster Carr Supply. I kept 4 of the rings and gave 6 of them away to other members.
Now I have some rings, just in case I have a problem.
Stewart
Old Dec 23, 2006 | 08:32 PM
fxstbchopper's Avatar
fxstbchopper
I have see a drop in fuel mileage with the ULSD so I have been going to the only station in town that has Bio Fuel. I use diesel kleen in every tank as well.
Old Dec 23, 2006 | 08:35 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
You know you don't need to add the additive to fuel if you use the BioDiesel...
Old Dec 23, 2006 | 08:42 PM
fxstbchopper
Yes but when it gets cold it is still hard to start if I don't have it in the tank don't know why but if I use kleen I don't have any problems.It is B2 soyfuel I don't run kleen till it turns cold.
Then I run it in every tank.
Old Dec 24, 2006 | 09:58 AM
John311t's Avatar
John311t
i hate ulsd, i get worse mpg.
