knock sensor and 02 sensor
Old Dec 22, 2006 | 02:04 PM
1994flareside's Avatar
1994flareside
Hello,
Just wanted to know when is the right time to change these to sensors. I'm the second owner and don't think that they were. The truck has 163,000 miles everything is stock nothing has been changed except the A/C compressor. Its a 302. Thank You.
Old Dec 22, 2006 | 03:24 PM
MustangGT221's Avatar
MustangGT221
I'd say until you get a check engine light, if it ain't broke don't fix it.
Oxygen sensors are part of the tune up stuff though...if you care about peak performance than you can spend $50 for an oxygen sensor and it may give a little more accurate information to the computer for a slightly more efficient fuel/air mixture but if it's running fine than I'd leave it alone.
Knock sensor isn't really a wear item or a major concern, it's inplace to detect detonation and tell the computer to retard timing if necessary...most of the trucks don't even have this sensor.
