quick question
Old Dec 22, 2006 | 01:45 PM
Dizz0129's Avatar
Dizz0129
quick question
i got some Autometer Sport-comp guages and i was installing the Boost guage using the Boost "T" into the map sensor...got it all together and started it up...there was no reading at all...what coulda went wrong
Note:none of the electric for lights was installed yet but it was all in the pillar and ran to where it needed to go just not connected
2002 PSD 7.3
Old Dec 22, 2006 | 01:51 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
Go take your truck for a drive, and see if it moves. Get on it pretty hard and load the engine down. It will not move at idle, because there is no load on the engine. You gotta put some strain on the engine to produce boost. It's mechanical, so you don't need electric to make it work, so go try it out now.
Old Dec 22, 2006 | 01:53 PM
Dizz0129's Avatar
Dizz0129
so even revving it wont make it go up?
thought that that would
ill try it
Old Dec 22, 2006 | 02:01 PM
PowerstrokeJunkie
Nope, revving it in idle puts no load under the engine.
Old Dec 22, 2006 | 02:08 PM
Dizz0129's Avatar
Dizz0129
ok took it for a ride
thanks strokin
got 29lbs
is that good with a chip and exhaust?
Old Dec 22, 2006 | 02:17 PM
ponch37300's Avatar
ponch37300
29 is good. If I remember correctly 23 is what the truck is set to defuel at and set a code. Do you have a boost regulator for your map sensor?
Old Dec 22, 2006 | 02:19 PM
Dizz0129's Avatar
Dizz0129
yes the dual relief valve
