A little help with question or two please.
Old Dec 22, 2006 | 10:30 AM
nickle&dimeya's Avatar
nickle&dimeya
Question A little help with question or two please.
ok what years did 7.3 psd us the same injectors and what were if eny were the diffrence between the 95 to mid99,then mid 99 to last build?? and i am thinking of replacing my Turbo Compressor Wheel is there a diffrence agein from95/99/and99/last build.and how hard is it to do?? thanks all
Old Dec 22, 2006 | 10:43 AM
nickle&dimeya
what is this thing eny good and how do thay pull that hp out of this mod or is it boloiney PPE 7.3 ENFORCER- 99-03 FORD 7.3 L PS DIESEL
175 HORSEPOWER!!-
175 Horsepower350 Ft/Lbs Of Torque and if so is it a good mod????
Old Dec 22, 2006 | 11:43 AM
kbeefy's Avatar
kbeefy
whoa, can't awnser your injector questions aside from saying they're not that hard to change, pull the valve covers and they're right there.
For you second post, put a few more details in there. I've got no clue what an enforcer is. There are packages out there that will get you that kind of power, usually require injectors, turbo, hpop.
Old Dec 22, 2006 | 11:45 AM
nickle&dimeya
wow no one out there to day lol...but i forgot to ask will a new turbo wheel give me more hp or performence thanks all happy holidays!!!
Old Dec 22, 2006 | 11:47 AM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
I read it a while ago and i was hesitant to respond to it due to the poor grammar and punctuation. I had to read over it three or four times and i still didnt get 100% of the meaning of what you asked.
But a compressor wheel will not gain performance. It actually lowers it, but in turn reduces/eliminates compressor surge due to a chip or tuner. Don't let anyone fool you into thinking that the WW will gain performance.
Old Dec 22, 2006 | 11:51 AM
nickle&dimeya
k beefy if you have ebay look up this item ####Item number: 120064917602 that will tell you more.lookes like a bunch of plugs ipr,ipc ect
Old Dec 22, 2006 | 11:58 AM
nickle&dimeya
sorry i was woundering what the diffrence from 1995 to 99 1/2 ijectors from psd.to the new style 99 1/2 to 2003 psd.and if thay are interchangable.2nd the wheel, if mine is chiped but still works good(2 fins are chiped slightly) if i stick a banks wheel will it work beter.is it hard to switch the wheel to put on my truck.
Old Dec 22, 2006 | 12:44 PM
Uzumati's Avatar
Uzumati
The 99.5-03 had larger injectors I dont think they are interchangable. As far as the banks wheel it is nothing more than a wicked wheel (early 99 turbo) for more money looking at it. The wicked wheel will spool faster on the bottom end but will produce about 2psi less boost on the top. Kris is dead on about the wheel All it does is raise the point at which surge/Stall occures. An ATS ported housing completely eliminates surge due to its design.
Old Dec 22, 2006 | 12:53 PM
Tenn01PSD350's Avatar
Tenn01PSD350
I don't think they are interchangeable, they have different part numbers. Of course that may not mean anything.
<table border="1" cellpadding="5" cellspacing="1"><tbody><tr><td>Injectors</td><td>Federal emissions and SuperDuty</td><td>F81Z-9E527-DRM</td></tr> <tr><td> </td><td>96/97 California emissions and all 98.5/99</td><td>F81Z-9E527-BRM</td></tr> <tr><td> </td><td>99.5 and up</td><td>F81Z-9E527-CRM</td></tr> <tr><td> </td><td>97-99 Cackle Fix; #8 cylinder ONLY</td><td>F81Z-9E527-EARM</td></tr> <tr><td> </td><td>99.5-2000 Cackle Fix; #8 cylinder ONLY</td><td>XC3Z-9E527-AARM</td></tr></tbody></table>
Old Dec 22, 2006 | 01:08 PM
nickle&dimeya
ok all thanks happy holidays
Old Dec 22, 2006 | 11:48 PM
nickle&dimeya
ok if i have low fuel pressure will my truck sound louder,like injector noise
Old Dec 23, 2006 | 09:07 AM
cangim's Avatar
cangim
It will sound different when you get into it a little, but at idle, unless it is way low, it shouldn't sound any different at idle.
Old Dec 23, 2006 | 09:11 AM
nickle&dimeya
ok what should the pressure be when i check it thanks
Old Dec 23, 2006 | 11:21 AM
PowerstrokeJunkie
Factory pressure will be about 53psi. Lowering fuel pressure at idle will make it run smoother, and raising it will make the injectors noisier, im talking upwards of 80-90 psi at idle.
Old Dec 23, 2006 | 11:28 AM
nickle&dimeya
i think some one told me that the more fuel pressure 80-90 would make the injectors run more quite,that must not be true.but heres the scoop i had to replace my hpop and before i did that it would blow black smoke with the chip,and now that it has a new hpop it dont blow no black smokewith the chip,so im thinkin weak fuel pump. what do you think??
