Ok So First Of All I Know Close To Nothing About Rwd.... That Being Said My Awd Talon Took A Crap On Me And My Grandmother Gave Me Her 91 Ranger To Drive Till I Fix It.... Heres The Problem, There Is A Serious Tranny Leak... There Is Fluid Running From The Front Of The Bell Houseing Back And Also Running Down One Side Of The Tranny Pan... What Could This Be... Is This Just Some Old Seals If So Which Ones And Could A Weekend Warrior Kind Of Mechanic Type Person Fix It... Thanx In Advance For Any Help...
First off, a little more info before we can make suggestions.
Is it a manual or automatic transmission?
Is the fluid engine oil or transmission fluid?
If engine oil, it could be the rear main seal. If transmission fluid it could be the front seal to the transmission. And depending on what transmission just how hard that could be.
Here's what I think. Probably the front seal on the transmission. Heavy but do-able.
Now it could be fairly simple, but I have seen this same thing when the torque converter was bad.
I think if I was doing this, I'd pull the converter and have it checked. Also I'd look very close at the seal. If it's damaged, then you probably have found your problem.
Hello,
Check out our website, for codes and thier fixes. We can also supply you with the parts to fix your trans. We also offer upgrade and performance parts
for your vehicle.We can also answer any questions you may have.
