Cab corners
Old Apr 27, 2001 | 07:19 PM
jan's Avatar
jan
Cab corners
I know what I need but I don't know what it is called... Anyhoo, I need the piece that goes from the front cab on a 60 F-100 to the front cab mount, seems this part is causing my fenders to pull away from the cab. Will I be better off fabricating or what ???
All help will be appreciated.
Bob
Old Apr 28, 2001 | 12:51 AM
darkman's Avatar
darkman
Cab corners
I think you are talking about the area that is near where the fender bolts to the lower front portion of the cab. Is that right?
Charles
Old Apr 28, 2001 | 04:08 AM
jan's Avatar
jan
Cab corners
That's correct, it's at the lower corner of the inner fender, they tell me it(whatever they call it gets weak). I've tried several links but so far no luck, thanks for responding.
Bob
Old Apr 28, 2001 | 07:30 PM
darkman's Avatar
darkman
Cab corners
Lower corner of the inner fender. Your talking about the fenderwell or just the inside of the fender? I guess it doesn't matter cause they dont make either one aftermarket. It is a salvage yard item. The inner fenderwell has a bracket that bolts to the cab and then the fender bolts to the bracket. It would not be too hard to fabricate. The fender bolts to the lower outside bottom corners off the cab. That is probably where you are talking about. Depending on the extent of the rust it could be hard to do. Mine 57 has a tab that hangs down. is that where your rust is?
Charles
Old Apr 28, 2001 | 07:45 PM
jan's Avatar
jan
Cab corners
Guess you are right, I'll have to take off both fenders and I'll know alot more but again thanks
Old Aug 13, 2001 | 11:38 PM
nice59fordf100's Avatar
nice59fordf100
Cab corners
jan, is this what you are talking about?http://www.members.tripod.com/nice59fordf100/1b840f00.jpg
http://www.members.tripod.com/nice59fordf100/1b340f00.jpg
hope this helps
-Russell
Old Aug 14, 2001 | 09:19 AM
darkman's Avatar
darkman
Cab corners
I could not display the pictures please try again or post a link.
Thanks Charles
Old Aug 14, 2001 | 10:49 AM
nice59fordf100
Cab corners
ok, if the pics didnt pull up on the last reply, here is the webpage i got them from. these are pictures that i took with my digital camera so i hope that can help. if you ever need a pic of something for a reference emal me and i will take a pic and uplaod it for ya in a matter of minutes. nice59fordf100(No Email Addresses In Posts!)
here is the web address with all 4 cab corners on them.
http://www.members.tripod.com/nice59fordf100/id3_m.htm
Old Aug 14, 2001 | 10:53 AM
nice59fordf100
Cab corners
