Fuel Filter Change Observations/Comments
Old Dec 21, 2006 | 08:01 PM
eb2006's Avatar
eb2006
Just now have 15K on my truck so I figured it was time to change the fuel filters. I went to IH and got the ones everyone here recommends along with the brass drain plug and then went to the tech folder to take a look at the procedure. 15-20 minutes later I was all done and the truck running. With that said, I have a couple of observations/comments:
  1. Thanks to SBV45 for the procedure in the tech folder....absolutely perfect.
  2. Couldn't Ford find a better place to put the HFCM? On the 4X4 I have, I almost thought I would have to remove the front drive shaft to get the old filter out. As it turns out, I didn't have to put it did cause additional diesel fuel to run down my arm!
  3. I use DieselKleen on a regular basis so I wasn't expecting to see any water to come out of my HFCM (in which I didn't) but I did start wondering....How much water will trip the sensor? A drop? teaspoon? Any idea?
  4. Thanks a bunch to this forum.....seems like I pick up some new knowledge everytime I am on here.
Off I go now to try to rid myself of diesel fuel so the wife can quit bugging me about it!
Old Dec 21, 2006 | 08:47 PM
DesertDave's Avatar
DesertDave
I don't have my owners manual handy, but when I read it a week ago I swear that in the diesel engine supplement it stated how much water was necessary to trigger the light. Thought it was something like 100ml.
Old Dec 21, 2006 | 09:14 PM
mrxlh's Avatar
mrxlh
Wow, I commend you for your efforts, glad you were able to "figure it out" with what was in the tech folder. I may steal this quote and insert it into a different thread for effect.
Old Dec 21, 2006 | 11:16 PM
Beachbumcook's Avatar
Beachbumcook
Got Diesel?
No water in the large HFCm filter is becuase you have purchased good fuel... it is not becuase of the DieselKleen.
DieselKleen is a great additive and is what I use. It is designed to help seperate any/all water and moisture and make it easier to be collected. Unlike gas engine additves that use alcohol... alcohol allows water to be attracted to the gas and be burned... but this is very bad for diesels and will blow the tip right off the injector.
The Dieselkleen helps make the water droplets bigger and easier for the OEM spec'd fuel filter (which you got from Int'l) to seperate and stay in the filter housing and not be sucked up into your motor!!!
Dieselkleen in every tank is good practice (or any "diesel only" additive of your choice). The fact that you did not see water or have any is due to getting your fuel from a high volume and good fuel retailer.
Good luck and enjoy... and your truck will thank you with reliable service for taking care of her like you are doing.
Old Dec 22, 2006 | 12:56 AM
chili7's Avatar
chili7
Ryan, what was missing from the procedure? I'm coming up on 30k and need to look into whether I want to attempt this myself. I'm pretty handy and used to do all my own auto work, but not recently and not on my diesel. It looks pretty straightforward, all in all.
Old Dec 22, 2006 | 08:17 AM
Lonewolftx's Avatar
Lonewolftx
Arrow Because . . .
The reason it is mounted there on the rail as it is the lowest point of the fuel transfer system betwen the tank and the engine.
Old Dec 22, 2006 | 01:45 PM
mjlevi's Avatar
mjlevi
I have been changing my fuel filters (purchased from the local IH Dealer) every 5,000 mi. since new (now have 16,000 mi.)... I actually drain the HFCM everytime I refill the fuel tank and everytime I do that I observe some very small amount of sediment and maybe a half dozen very small droplets of water and these mysterious looking small white particles of who know what it may be...I refill at a very high volume truck stop which I know to be a new station so the underground tanks should be somewhat clean and a local brand new Hess station that turns over a large amount of Diesel also...I use Dieselkleen every fill up...but having even this small amount of water at every fill up disturbs me and that is why I drain as often as I do...at least I know the separator is working to have these substances drain out...but in my opinion... from the refineries to your local fill stations, from tanks to tankers, you never know what your getting know matter what fill station your using...better to be safe than sorry ...
Old Dec 22, 2006 | 03:54 PM
Rod Jr.'s Avatar
Rod Jr.
Should the fuel filters be changed at the regular interval of 15,000 miles or is it ok to wait for the sensor light to come on.
Old Dec 22, 2006 | 04:04 PM
olfordsnstone's Avatar
olfordsnstone
Don't mess with fuel filters! Change them every 15000 miles. The consequences of a restricted fuel system, so I have been told by Ford Techs, is collapsed injectors.
As I understand it, warrantee dispute could arise if no record of Mfgr reccomended maintenance is apparent.
Old Dec 22, 2006 | 04:14 PM
WilliesSD250's Avatar
WilliesSD250
The procedure is very straight forward. You will want a short neck 36mm socket like "lisle". It'll make removing the HFCM cap much easier. Other than that, just follow the instructions in the tech folder. If your handy with tool you can be done in less than 2 beers.
Old Dec 22, 2006 | 04:21 PM
WilliesSD250
Oldford got it right. Don't go beyond 15,000 on your fuel filters. In my humble opinion, every 5,000 is a bit early, but if you can get your filters (like most of us) for $28-$32 then why not? I personally change out every 10K miles or everyother oil change.
But everyone here will agree that the fuel system is as critical as the oil&oil filter and the Donaldson Air Filter. Keeping up on these 3 CRITICAL items as per the manufacturers schedule will help ensure a happy and long running diesel.
Old Dec 22, 2006 | 07:04 PM
Gun-Driver's Avatar
Gun-Driver
How do you get to/into the tech files?
Old Dec 22, 2006 | 08:25 PM
2005 Ford's Avatar
2005 Ford
I think I am inspired to change my own fuel filters. It sounds easy enough plus my dealership charges me about 150 bucks to change them, so that helped also.
Old Dec 22, 2006 | 09:40 PM
mrxlh's Avatar
mrxlh
Willie pretty much got you taken care of, I would however add get a "oil cookie sheet" from China-Mart, or an autoparts store if you don't want diesel on your driveway. The tech folder proceedure is more than adaquate for the average mechanicaly inclined person. It can be a tad messy, hence the large "cookie sheet". Of course I always recommend safety glasses, dirt, diesel and eyeballs don't mix. Print the post out, get all your parts/tools ready, and go at it. It's best if you don't have any background distractions, til you get the hang of it.
Like I have said to all people who pay the dealer to change their oil, this is the easiest by far of all the vehicles I have ever owned to change the oil and filter in. Other than a tad messy, the fuel filters rate a close second to the inline transmission filter.
One more thing, Ford will challenge your warranty claim due to fuel filters, I have first hand knowedge of this. Don't risk your injectors, let alone your entire warranty for less than $40 and 45 minutes of time.
Old Dec 22, 2006 | 10:45 PM
blackhat620's Avatar
blackhat620
Look at the "Sticky" at the top of the forum
" Read First: 6.0L Diesel: ..................Tech Folder.............. "
Hope this helps
