Replacing Oxygen Sensor
Old Dec 21, 2006 | 03:20 PM
demalagutti's Avatar
demalagutti
Hi
I have a 97 ranger 4.0 manual transmission. Check engine light came on and it showed a bad O2 sensor. Replaced it and the light is still on.
Do I need to reset the light so it won´t come back again? Does the simple act of replacing the sensor would make it come off or do I need to do something else?
Thanks
Old Dec 21, 2006 | 10:00 PM
rbengl's Avatar
rbengl
Did you replace the correct one?
I have a 96 4.0 manual and there are three on mine. One on each header pipe in front of the cat and one in the pipe after the cat.
Old Dec 22, 2006 | 12:39 AM
tomw's Avatar
tomw
It should go off after several (don't know how many) successful engine start-run-shutdown cycles.
I'd check the fuses and the wires to the O2s... burnt insulation or loose connectors.
O2s last a LONG time unless you kill them. With lead, silicone or anti-freeze.
tom
Old Dec 23, 2006 | 08:43 AM
pawpaw's Avatar
pawpaw
Well you could pull the fuse to the ECM in the underhood power distribution box, for say 20-30 minutes.
That should clear the code, & turn the CEL off, without wiping out all your clock, radio, ect, presets. But it might run a little rough until it relearns it's idle, ect.
Or after a battery disconnect, which will clear codes & all your presets & idle strategy, to aid the computer in quickly relearning idle stradegy, I usually restart mine cold, let the initial fast idle come down some, then slowly shift my auto tranny, into all gears, including reverse, such that I feel them engage, then let it fully warm up at idle in "N" or "P", then repeat the gear shifting at warm idle.
Another option would be to clear the code with a code reader, or scan tool.
If you don't have one, most autoparts stores do & can clear the code & you won't loose your presets or idle strategy.
Just some options to ponder.
Old Dec 23, 2006 | 09:31 PM
MazdaRangerGuyInSTL's Avatar
MazdaRangerGuyInSTL
What code(s) did you get?
