5.0L engine exchage
Old Dec 21, 2006 | 01:50 PM
silver33's Avatar
silver33
Question 5.0L engine exchage
can someone tell me if a 1988 f250 5.0 will bolt rite into a 1994 f150 without
changing any wiring.Thank You
Old Dec 21, 2006 | 04:11 PM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
if they are both speed density, then yes. you might have to switch out the sensors/intake, but the 302 block should be the same
there are some late model 94's out there though that have a 302 with the 351 firing order/cam. I have one of these. this motor will still work, you just have to look at a chilton and run the spark plug wires to the correct cylinder
Old Dec 21, 2006 | 06:12 PM
silver33's Avatar
silver33
thank you.mine is a 351 fire order.i guess i have 2 check 88 engine.as i herd changing
fire order reduces h/p
Old Dec 21, 2006 | 06:30 PM
EPNCSU2006's Avatar
EPNCSU2006
It's not so much the firing order that makes less power, it's the cam design in general. You could swap your roller cam and lifters into the 88 block and it would be just like the 94 engine.
Old Dec 21, 2006 | 06:42 PM
silver33's Avatar
silver33
thank you 4 the info.been a great help.
