Multi plug trailer socket??
Old Dec 21, 2006 | 01:13 PM
jtexfisher's Avatar
jtexfisher
My '03 E-350 ... only has 7 pin socket for the trailer.
We tow both travel trailer and boats with this, and ALWAYS seem to loose the 7 pin to 4 pin adapter. Only when we need it of course.
Has anybody swapped in a socket like the F series has with both 7 and 4 pin on the same 'plate'??
Thanks!
jtex
Old Dec 21, 2006 | 02:16 PM
subford's Avatar
subford
Why not just put a 7-pin plug on the boat trailer?
Old Dec 21, 2006 | 04:08 PM
al_e._gator's Avatar
al_e._gator
I haven't swapped one in but I did install one from scratch on my 04 E350. I bought a Hoppy 7/4 pin combined connector and spliced it. I soldered the wires and covered the connections with heat shrink tubing to guarantee a good connection and protect from weather. I think I spent 30 minutes doing the actual splicing. If you can find a factory F150 connector you might be able to swap out the pins between the connector housings.
Old Dec 21, 2006 | 04:45 PM
jtexfisher's Avatar
jtexfisher
7 on the boat would be ok, but we pull other folks boats too now and then.
I found 'HOPPY'... www.trailerwiring.com. Now to search their products. That just might do the trick!
Many thanks!
Old Dec 21, 2006 | 06:19 PM
pfogle's Avatar
pfogle
Look at Wal Mart... They have the largest selection of the Hoppy line I've seen anywhere.
Old Dec 22, 2006 | 06:28 PM
al_e._gator
I used Hoppy model 47185 and cut off the four pin connector to hard wire everything. I think I got mine at Wal-mart but it could have been at Northern Tool instead.
Old Dec 23, 2006 | 05:26 AM
Adventure's Avatar
Adventure
Buy a second 7 to 4 way adapter, stuff it into a zip loc bag, and zip tie it up under the bumper. For $5 it's the easy solution I can think of. I keep one in the van and one in the trailer emergency box just in case.
