injection pump and injector questions
If I switch out only the injectors, and not the ip will I still have to adjust the timing?
Thanks,
Kyle
87 F250 6.9 daily driver, xcab, 4x4
gathering parts for wvo conversion.
86 f250 6.9, xcab, 4x4, plow
The timing light you have will only work if you have a pulse adapter that clamps on the #1 injection line to sense the fuel pulse and then translate that into an electrical signal for your timing light. These pulse adapters sell for a couple of hundred dollars.
If you change your injectors, it will probably change your timing since the old injectors have weaker springs (from cycling millions of times) and therefore "pop" (spray fuel) at a lower pressure than the newer ones would. That means that they "pop" a little sooner than the new ones would - so the timing would probably need to be advanced a little to compensate if you installed the new injectors.
New injectors on an old pump is not a good idea anyway. Because the new injectors will take more pressure to make them "pop", it will put additional load on the pump and, given its age, probably cause it to fail in pretty short order. Pumps and injectors should all be changed at the same time as a set.
So, if you are going to change anything, swap both the pumps AND the injectors between the two motors, then either get a pulse adapter, or take it to someone who has one, and get the timing reset on both motors. Of course a diesel specialty shop will be the only ones who have the pulse adapter and know how to use it. Most decent shops can re-time a motor in just a few minutes. Heck, Spectramac and I did mine in a parking lot in about 15 minutes. If you take both trucks in at once and talk real nice to them, you might be able to get them to do both motors for whatever their one-hour minimum charge is.....
