Cab leaking
Old Dec 20, 2006 | 07:12 PM
ellsdemon's Avatar
ellsdemon
Cab leaking
Does anyone know how to stop water from gettng into the cab? It leaks from the corners in the upper floor panel. I live in the northwest so this is usually going on alot. I own a 1973 custom, if that helps. Thanks
Old Dec 20, 2006 | 11:49 PM
GeneStoner's Avatar
GeneStoner
You might need some new inner fenderwells. If you can't find them, you may just have to repair the ones you have (made of a rubber material).
Old Dec 20, 2006 | 11:51 PM
Torque1st's Avatar
Torque1st
Posting Legend
A leaking windshield or around the A-pillar can cause this also.
Old Dec 21, 2006 | 03:25 AM
73f350sc's Avatar
73f350sc
Caulking lots of caulking haha.. serisouly though look and see if you dont just need a new windshield seal. If its original it could have shrunk over the years or dired out and cracked.
-Chris
Old Dec 21, 2006 | 10:00 PM
timothy47129's Avatar
timothy47129
You can use caulk on some stuff,but not just any caulk.The ge silicone 2 is the best thing on the market.It is 100% silicone.I used that for the seal between my firewall and heater box.I was getting a whole lot of water in my truck in the rain from it splashing in around the heater box.Now its hard to keep water from comming in when the bottom of your cab is 2 1/2 feet from the ground and your ankels are in water.I havent yet solved that one,other than trying to stay out of the deep water.lol
I would have someone hold a water hose above the window and you sit inside and look for leaks.
Tim
Old Dec 22, 2006 | 10:34 AM
Todds79's Avatar
Todds79
Check the small drain holes in the corners of the cowl. These can get clogged by leaves. Water then fills the cowl and spills into the cab. It took me a long time to figure this out with my 79.
