350 SD Engine issues
Old Dec 20, 2006 | 10:39 AM
empirestacktesting's Avatar
empirestacktesting
Question 350 SD Engine issues
I bought a used 2005 F350 SD with the diesel & AT.
we got it last February and we now have ~50,000 miles on it
we tow a 8000lb trailer ~600 miles every other week.
when we first ran the truck we were getting 18 mpg w/out the trailer and 15 mpg with it.
now we only see 12 mpg w/out, and 5-10 with.
we also get alot of smoke when we start the truck (cold or not)
two dealers have worked on it:
we have 7 new injectors, new mass flow sensor, new mass flow valve (?), new partial wiring harness.
Any suggestions?
Old Dec 20, 2006 | 11:14 AM
BowTieHatr's Avatar
BowTieHatr
what color smoke?
Old Dec 20, 2006 | 11:47 AM
empirestacktesting
very thick white smoke
Old Dec 20, 2006 | 01:26 PM
Reidicus's Avatar
Reidicus
I have a same sort of problem. Lots of white smoke and a terrible smell inside the cab. Thats usually on startup. When its warmed up, it still smokes a little. Almost a blue color exaust. Yea, and the Turbo is cycling over and over. MPG has gone down to 14. Unplugged my EGR Valve. Terrible lag on startup and acceleration.
Old Dec 20, 2006 | 02:21 PM
empirestacktesting
2005 350 diesel issues
I forgot about the turbo issue.
This doesn't happen all the time, but when it does boy is it loud!
When towing, and after a hill, we get a loud racing sound.
(It sounds alot like my 250 460 gas engine downshifting.)
But we can't detect what causes it or why.
The turbo boost doesn't jump, neither do any other guages.
Of couse the dealer can't find anything.
Old Dec 20, 2006 | 06:05 PM
killaford's Avatar
killaford
When towing, and after a hill, we get a loud racing sound.(It sounds alot like my 250 460 gas engine downshifting.)
sounds like the cooling fan?
Old Dec 20, 2006 | 06:41 PM
BowTieHatr's Avatar
BowTieHatr
did the white smoke start after the injector replacement?
Old Dec 26, 2006 | 05:23 PM
Scotter06's Avatar
Scotter06
Reidicus-
I have been having the same problem. 2004 350 with about 39K miles on it. I have been noticing lag in the turbo and accel and reciently I have been noticing the white smoke. At first it was not very bad just a little bit, but its been getting worse and worse. Just today I went to start my truck and it would not turn over, just cranked for maybe 30 seconds, then once again the same, on the third try the truck started after about 15 seconds and then my truck just started pouring very thick white smoke. Enough to fill my front yard and make the neighbors look outside. Anyone know whats going on?
Old Dec 26, 2006 | 06:01 PM
urraco's Avatar
urraco
When mine did that it was head gaskets. The racing noise you are hearing is the cooling fan cycling on.
Old Dec 26, 2006 | 06:28 PM
bocomojoe's Avatar
bocomojoe
You're saving fuel, you are 'burning' water from somewhere. Head gasket, or maybe thru the fuel system. I'm not sure how water could get thru the new fuel system but maybe. Good luck.
Old Jan 5, 2007 | 01:54 AM
luckycruiser's Avatar
luckycruiser
white smoke
Did you figure out your problem? I just started having the same problem today. Lots and lots of white smoke.
Originally Posted by Scotter06
Reidicus-
carmk
All Things Towing
17
Feb 26, 2007 10:05 AM
toolebox1
13
Jan 4, 2007 01:51 PM
uask4it
New Member Introductions
Dec 6, 2006 02:15 PM
rc12306
2004 - 2008 F150
Nov 27, 2006 04:12 PM
