I have a '93 F150 Supercab, used the tools to try and remove the radio. It won't come out!!!
Is there something that I am missing? I have looked at as many posts as I can find regarding this subject and haven't seen anything.
I can feel the latches release when I use the tool but the radio won't budge, not forward, sideways or anything.
Does anyone have any suggestions.
Before you ask: Yes, I am sure that they are ford removal tools.
When I removed the one outta my 93 I had a helper pull on the removal tools while I reached up behind the dash and pushed the radio. Made it a little easier at the time.
On mine I had to push the tools in then kind of twist a little bit on each side then wiggle around with them a little bit. It was still a pain in the rear and took a couple of tries but I did get it to pop out eventually. Keep trying, it will come to respect your authority eventyally.
