roller converson cams?
Old Dec 20, 2006 | 09:45 AM
s1120's Avatar
s1120
OK, well I have a full roller setup out of my blown 95 5.0L motor. From what I have heard, I need to run a smaller bace circle cam to convert my early 351w block to roller. Is this right? Who makes these, and are there anygood ones for a MAF inj 351 in a 95 Bronco? Thanks for any help!!
Old Dec 22, 2006 | 11:56 PM
TigerDan's Avatar
TigerDan
Most of the major cam manufacturers offer them, but not too many different ones so the grinds are somewhat limited. You should be able to find them at Summit or Jegs.
Old Dec 23, 2006 | 03:53 AM
darrin1999's Avatar
darrin1999
it would be easier to just find a roller 351 fuelie block in a junkyard because the fuel injection stuff off your 5.0 wont fit the 5.8- 5.8 engine is wider by i think 1 1/4 inches, but the 95 351 block should already be roller, or should have the proper block for a roller setup already- so no special cam required
Old Dec 23, 2006 | 07:24 AM
baddad457's Avatar
baddad457
A SD friendly small base cam's going to be a tough to find item. Might be cheaper to source a roller 351W block and use the std base cams.
Old Dec 23, 2006 | 10:23 AM
TigerDan's Avatar
TigerDan
He said MAF...
