Sponsored by: Real Truck
Center Bearing Check?
Old Dec 19, 2006 | 09:30 PM
Shepard69's Avatar
Shepard69
I have an 02 F350 super crew. Getting a real bad vibration under any load and worse the faster I go with my foot into it. Crawled under to check the U-joints and they seem good. But I can move the drive shaft a 1/2 inch in any direction really easy around the centre bearing. The Rubber "thingy" seems worn out? Should I be able to move the rubber cushion?
Old Dec 19, 2006 | 09:33 PM
69cj's Avatar
69cj
To my knowldge you have a center bearing to replace. 1/2 inch equals vibration and normally with window down at about 35 to 40 you should hear it.
Old Dec 19, 2006 | 09:47 PM
Shepard69's Avatar
Shepard69
To dam cold up in Canada to drive with the window down. But I don't think I should have that much play. Can some one go check their center bearing play. May someone who doesn't have snow on the ground.
