94 F150
Old Dec 19, 2006 | 11:42 AM
badass truck's Avatar
badass truck
94 F150
hi guys I have a 1994 F150 two wheel drive i just recently had the oil pan gasket replaced cause it looked like it was blown out of the sides of the oil pan. do you guys think i should have had the rear main seal replaced also?? and also it is leaking anti freeze out of the front right bolt on my intake manifold. right above the thermostat essentially. anti freeze was coming up the threads on this bolt and leaking out the top i went to pull the bolt and put some sealant on it but when i tried the bolt broke in half and was corroded away. is this very common thing among fords or is this kinda a rare thing
Old Dec 19, 2006 | 12:13 PM
95Ford4x4's Avatar
95Ford4x4
you'd have to pull the tranny to change the rear main seal, not hard to do yourself, but time consuming, and would probably not be cheap to take to a shop and have them do it. can't help you with the bolt problem, you didn't mention what engine you have. i have had the thermostat housing bolt corrode in two on a big block 351, one reason i never run just pure water.
Old Dec 20, 2006 | 12:38 PM
badass truck
I have a 302 in my truck sorry lol
thinksnow
2004 - 2008 F150
Mar 5, 2013 05:24 AM
96broncoXlt
1978 - 1996 Big Bronco
30
Jan 8, 2012 05:22 PM
Customlover
Jun 10, 2011 09:51 PM
Ranger1F150
May 27, 2007 08:20 PM
Dennis of KC
Nov 25, 2003 01:29 PM
