Fuel level sending unit
Old Dec 19, 2006 | 09:23 AM
rustydailey's Avatar
rustydailey
Does anyone know where I can get just the sending unit. Or does it come with the pump assembly.
Thanks
Old Dec 19, 2006 | 09:27 AM
Tenn01PSD350's Avatar
Tenn01PSD350
Do you mean the fuel pickup assembly? The fuel pump is mounted outside the tank on the frame rail under the driver seat.
Old Dec 19, 2006 | 10:35 PM
rustydailey
I am looking for something to fix my fuel gauge. It dosen't read right. So I figured that I could just replace the sending unit. But I'm finding out that that isn't the case.
Old Dec 19, 2006 | 10:50 PM
Tenn01PSD350
Yeah, it may not be. I even checked Millenium Ford earlier and could not find it listed. I know you can get it but I'd hate to send you to the dealer. Anyone else? Stand By.
Here is a pic of the float and sending unit minus the pickup foot and mixing chamber. Yes, that is what currently resides inside my tank. More to follow.
Old Dec 19, 2006 | 10:56 PM
Uzumati's Avatar
Uzumati
Its under the colision catalog
http://www.trademotion.com/partlocat...10&catalogid=2
Old Dec 19, 2006 | 11:01 PM
Tenn01PSD350
Damn Alan, good work. I never thought to look there. Anywhooo. Are you sure you need a new sender Rusty? What exactly is going on?
Old Dec 19, 2006 | 11:09 PM
Uzumati's Avatar
Uzumati
Testing the gauge itsself takes a special tool, or a couple of resistors valued at 15 and 160 ohms.
Old Dec 19, 2006 | 11:16 PM
Tenn01PSD350
Understood Alan. Just wondering what he is seeing so I can file it away for future forgetting.
Old Dec 21, 2006 | 06:55 AM
rustydailey
Well it's kinda hard to troubleshoot it since I'm in Kuwait. But the wife says that it will show 1/4 tank and just die, the light won't come on or anything. She will add some fuel to it and it will start right up. So that sounds to me like the sending unit.
Old Dec 21, 2006 | 08:09 AM
Uzumati's Avatar
Uzumati
Does it read "correctly" down to 1/4 tank or is it just stuck on 1/4.
Old Dec 21, 2006 | 08:13 AM
jisl's Avatar
jisl
I have a '99 PSD and it does the same thing. I'm looking forward to the resolution so I can fix mine. I've been living with 1/4 of a tank being the empty mark...
Old Dec 21, 2006 | 08:35 AM
Uzumati's Avatar
Uzumati
jisl and rusty have you done the hutch mod?
Old Dec 21, 2006 | 09:58 PM
rustydailey
No I haven't done it. I got the truck about a month before I deployed.
Old Dec 21, 2006 | 10:16 PM
Tenn01PSD350
Rusty, thanks for your service and stay safe. I doubt the problem resides in the sending unit. Nonetheless. When the truck gets down to near 1/4 tank, have her fill it up and see how much it takes. Eg: 39 gal tank around 1/4 full ought to take about gee something like 28-30 gals. Anything over 32 and I would suspect a sending unit or gauge problem but I suspect something else is afoot here.
Edit: didn't mean to be mysterious or anything, I suspect you have a fuel supply problem that gets exacerbated when the tank gets lower. If this is the case, it is something sensitive to lower pressure at the pickup foot. Among the items that come to mind are clogged pickup/strainer and a possible pump heading south but we are way ahead of ourselves until we determine that indeed the truck gauge/sender is not faulty.
Old Dec 21, 2006 | 10:35 PM
mudmaker's Avatar
mudmaker
I experienced the same thing once on my 02, 1/4 tank on the gauge and it ran out of fuel, but when I looked at the trip computer it read correct 0 miles to empty. The problem on mine hasn't repeated itself, that was more than 50000 miles ago.
