Tire Pressures
Old Dec 19, 2006 | 09:07 AM
onelostokie73's Avatar
onelostokie73
Tire Pressures
Just something to think about. I know a lot of you are very proactive about maintaining your Ford trucks. Just a little reminder here......Make sure to check your tire pressures. I regularly check my tire pressure so imagine my suprise when ALL of my tires were 8-10 psi low the other day. I didn't even stop to think that the temperature had dropped by approximately 20 degrees. That is enough to make your gas mileage drop just as well. Anyway, I just thought I would throw that out there.
Old Dec 19, 2006 | 10:09 AM
flyfishtn's Avatar
flyfishtn
Every Saturday morning.
As well, somehting to add to this, check your tire pressure when your tires are cold.
Old Dec 21, 2006 | 12:55 PM
bobbylh's Avatar
bobbylh
Don't forget the spare. You might need it one day. Mine had 20 lbs in it.
Old Dec 21, 2006 | 09:17 PM
preppypyro's Avatar
preppypyro
If you are too lazy to check your pressures, head to your local tire shop. Most shops check, and fill/deflate them as needed, for no charge.
Old Dec 22, 2006 | 08:32 AM
DJR 17's Avatar
DJR 17
What is the recommended pressure for the BFG's stock 18" tire's? Mine were at 45 psi from the dealer/factory.
Old Dec 22, 2006 | 10:12 AM
sgt82nd's Avatar
sgt82nd
The recommended tire pressure should be on the inside pillar drivers door. In addition to the cold tire tip - use a dial guage. The pocket guages aren't accurate. You can use the dial guage to calibrate your pocket guage if you want to keep it in your dash.
