1951 F5
Jul 26, 2001 | 09:13 PM
1951 F5
Who sells parts for a F5? Most catalog companies sell only F1 parts. How can I get the part numbers used on a F5?
Parts I need are:
A adapter to convert to a dual master cylinder. What dual master cylinder will work with the bigger brakes on the F5.
Drum brake shoes.
Rubber for the steering components.
It has a rear brake light bracket on the driver side. Is a driver side bracket available for the right side? I would like to install turn signals.
A alternator bracket for a single wire GM alternator for a 239 flathead V8 and pulley.
A center driveshat support (is it bigger than the F1).
The three universal joints (are they different from the F1).
Bolts that attach the springs to the chassis.
5 driver side wheel lugs and 5 passenger side wheel lugs.
Your help will be appreciated.
james.vick@home.com
Jul 26, 2001 | 11:32 PM
1951 F5
If you have a "larger" truck repair place by you, that may be a source for parts.
Wayne 60 F-350
e-mail
https://www.ford-trucks.com/users/whomrig
Aug 6, 2001 | 03:33 PM
1951 F5
Try Joblot Automotive, in Queens, NY. They seem to have quite a large inventory of old "big" Ford truck parts. Check out their website at http://www.joblotauto.com
Aug 7, 2001 | 08:53 AM
1951 F5
You might also try NAPA on-line. They have a free service for locating older vehicle parts. They helped with my 54 F-350 which shares some parts with the F-5, schoolbus, etc.
As far as the carrier bearing, I was able to adapt the 55 and later version with minimal work.
Sep 18, 2001 | 08:32 PM
1951 F5
I have a 1951 F3 compleate driveline inc. center support.
darrellmed(No Email Addresses In Posts! )
Sep 18, 2001 | 09:31 PM
1951 F5
I got all the parts I needed for both my 42 ton and a half and my 55 F600 at Napa. Take the old part with you it helps
Sep 19, 2001 | 03:57 AM
teardropty
Ford Truck Parts for Sale
May 13, 2013 10:37 AM
leebrown5
17
Apr 26, 2012 06:14 AM
2speed
Large Truck
Nov 18, 2010 11:48 AM
jimi
Aug 8, 2007 02:54 PM
ranger250Center
Feb 18, 2006 10:14 AM
1951 ,
adapter ,
brake ,
cylinder ,
f1 ,
f3 ,
f5 ,
f5ford ,
flat ,
ford ,
head ,
master ,
parts ,
specs ,
truck ,
trucks
