Head Gaskets Question
Old Dec 19, 2006 | 05:37 PM
ford4lifer's Avatar
ford4lifer
Originally Posted by 2006PSDSD
I was told that I could run those temp for short periods of time by Eric at ID. I think of it this way: if you take a turbo torch to a peice of copper, your solder won't melt until the pipe is heated to a temp that the solder will melt at. Basically saying that you have to sustain those temps for along time to damage anything, he told me that they run 1600-1800 degrees on their injector truck, but they only hit those temps for a 1/4 mile.
I hit 1400-1500 running Eric's extreme street tune under hard acceleration but it's only there for about 15 sec max @ 32psi boost, If I put Matt's dyna max race tune on I hit 1500-1600 @ 36 psi boost, I rarely use this tune only when I want to blow the doors off in very short distances, makes me kringe when I see the boost hit there. Luckly I haven't puked the engine yet!!
Old Dec 19, 2006 | 06:31 PM
SpartanDieselTech's Avatar
SpartanDieselTech
Former Vendor
Have you tested out the new file I sent a little while ago?
I pulled about 4 lbs of manifold pressure out; it should actually pick up some more power from that.
