New/used IP
Old Dec 18, 2006 | 05:38 PM
ram2miller's Avatar
ram2miller
New/used IP
My IP is leaking out of the bottom and I need to fix or replace. I have a used pump that seemed to work fine when last used, should I use this and is there anything I should do to the pump if I do use it? The old pump is leaking out of the allen head plug in the bottom I believe, can I tighten this allen or put in a new gasket or o-ring and fix this pump? Any ideas?
