priming 400 oil system
Old Dec 17, 2006 | 10:49 PM
nebechanezer's Avatar
nebechanezer
i'd like to prime my 400's oil system. my brother has a dist. he took the gear off to prime his 302. would that work on a 400? i also have an extra dist from another 400. could i use that w/out ruining it?
Old Dec 18, 2006 | 03:56 AM
d79f150's Avatar
d79f150
I would go to you local parts store and ask for a primer they are 15$ or less rather than tear apart a dist.
You would need to tear off the dist gear for it to work otherwise. Turning it at that high of a speed with a drill may ruin the dist.
Old Dec 18, 2006 | 06:09 PM
husker's Avatar
husker
As d79f150 said, use the tool. Some stores will(Autozone for one) will let you use the tool for a deposit and refund the money when you bring it back. That is what I did. Also remember that the dizzy runs counter clockwise, so you will need a reversable drill. When I did mine it pulled the drill fairly hard once it started to pump oil. I left the valve covers off to see that there was oil coming up through the push rods etc.
Old Dec 24, 2006 | 09:05 AM
clunker86's Avatar
clunker86
you can also use a 1/4 in drive extention and i dont remember the size of socket but its like a 3/8 or around there. make sure you tape the socket on and it should work. i did this before and had no problem but it also wouldnt be hard to have a big problem. key point dont lose the socket in the engine
Old Dec 29, 2006 | 01:29 PM
Rancheroracer's Avatar
Rancheroracer
It's a 5/16" socket, works fine. That's what I always do after reassembly on my Cleveland. Just be sure socket fits the extension snug.
Old Dec 29, 2006 | 05:27 PM
grclark351's Avatar
grclark351
what he said. you can have it done before you'd get to the store and get the stupid look like you have 2 heads from the kid. you need a rather thin-walled socket, i ground one down special for the job. wrap it with a piece of tape to the extension or speedhandle if you're worried about the socket falling off(tape doesn't stick to oily tools, carb or brake cleaner works great). the speedhandle is the best method i've found. spin up some pressure in the pump, then turn the crank some and spin up the pressure again. repeat until you're tired. i make sure that i have oil to every rocker before the coil wire goes on. unless you like that really expensive squeaking noise X16 when you start it? seen it too many times!
Old Dec 29, 2006 | 07:34 PM
Torque1st's Avatar
Torque1st
Posting Legend
I like it!!! -hehe
I use that white lithium assy lube on everything unless there is some special lube for the part.
A "slim" socket works great. I was playing with my torch one day and brazed a cheap socket to a cheap extension. Ground the outside down. Then threw it in the tool box. I may be able to find it when the time comes... The heat from the brazing ruined it for use as a socket but it will work to prime a pump. I use an electric drill. I am not coordinated enuf to use a spinner!
I get that two heads look all the time. Kind of similar to the deer in the headlight look. Remember, If they can't find it on their 'puter it don't exist.
Old Jan 1, 2007 | 02:57 PM
my3lilfordfans's Avatar
my3lilfordfans
lmao!!! i have had that problem to many times, if it aint in the puter isnt real! horse ****!! i went into shucks to order an excel ignition system.. changes over from points to that nifty lil box, anyways the parts guy who claimed to be a race mechanic told me i was nutz!! so now all my parts come from mail order
