Fuse box question
Old Dec 17, 2006 | 07:37 PM
cubman61's Avatar
cubman61
Fuse box question
Hi everyone I have a 86 f150 and the blower motor for the heat stopped working I go to the check the fuse and I found it melted in the box. It still worked had power on both sides of the fuse. I tried to pull it out but it won't come out. So I decided to cut the two wires and and put a external in. Now my turning signals don't work. Looking at the wiring diagram and it looks like there is a internal connection between fuse # 9 and fuse#5. If I am reading it right it would explain why I lost my signals. it looks like the gray w/ yellow wire is the feed for both fuses. If i'm right I just have to connect the # 5 fuse to that gray feed wire. That should take care of the signals then on to the blower motor.
