General Automotive Discussion
Hypothetical
Old Dec 17, 2006 | 05:40 PM
eigenvector's Avatar
eigenvector
Hypothetical
This one is for you Monsterbaby.
So my buddy has a car he needs to junk, but he offered me his tranny and rear-end.
Do you think a C6 and a 9 inch rear end would work on my 2000 Ranger 3.0 liter?
This would be out of his '73 Torino. I tried for the 351 but he wasn't going for it.
NO, neither one of us was serious. The weight of the tranny alone would probably double the GVW.
Old Dec 17, 2006 | 06:35 PM
fellro86's Avatar
fellro86
You would have to use an adapter plate and custom flywheel just to hook it up... the 3.0 uses it's own bell, shares with no other engines. The rear end can be made to work, that kind of thing is done all the time. Might need narrowed and the spring pads moved, but its doable.
Old Dec 17, 2006 | 07:37 PM
Krochus's Avatar
Krochus
And why would you wnat to do this???? A modern fuel injected vehicle (OBDII) Will absouletely freak out if you even attempt to install those parts .
Besides your ranger would get slower and use more gas with those parts. So again WHY??
Old Dec 17, 2006 | 08:38 PM
eigenvector
WHY???? Why?
I think the correct question here is - Why not?
Besides, I said it was only a hypothetical. I could always disable the emissions controls, score one of the cylinders, and put a hole in the catalytic converter and before you know it, I have a ...... piece of junk. Hey it wasn't my best idea, but at least I'm thinking outside the box.
Old Dec 17, 2006 | 09:29 PM
Racerguy's Avatar
Racerguy
The Torino rear end is pretty wide and it has coil springs. You'd need to do a lot of cutting to get rid of all the mounts before you could weld on the leaf spring mounts.
Old Dec 17, 2006 | 10:30 PM
arctic y block's Avatar
arctic y block
Go ahead and get them if they are cheep or free. Post on e bay and make a couple bucks.
Old Dec 17, 2006 | 10:53 PM
FirstTry's Avatar
FirstTry
why you ask? because man, thats where hot rods came from, guys taking older vehicles, throwing on parts that were not made to fit, and making them fit, may not have worked the first time, but they used their brains to make it work. ingenius. but i wouldnt put the c6 in there without the 351. YEE HA.
Old Dec 20, 2006 | 09:32 PM
I6power's Avatar
I6power
I would take this guys advice.
Old Dec 20, 2006 | 11:30 PM
Birddog63's Avatar
Birddog63
Hypothetically speaking... A C6 behind a 3.0=Boat anchor...
Otherwise go with arctic Y block's advice. If it's free take it!!!
