Code Help
Old Dec 17, 2006 | 05:28 PM
scottmoore's Avatar
scottmoore
Code Help
Hello guys,
I am having a problem with my 96 Bronco. It has a 5.8l with e4od trans. I have searched through the posts and didn't find what I need.
I was getting about 13.5 to 14 mpg, and then all the sudden it dropped to about 10 mpg. When it idles it lopes like it has a big cam in it. My cel came on and I have two codes. The main one that is always coming up it P0175 (rich mix on bank 2), the other that I only get every once in awhile is P0174 (lean mix on bank 2). I have checked for vaccum leaks and have none. I checked for a intake gasket leak and did not find one. I was thinking it must be the o2 since I am only getting the codes from bank2 so I changed it yesterday. The light has not come back on but it is still loping so I am not sure it is fixed. Do you all have any ideals? I do not know where else to look.
Thanks,
Scott
Old Dec 17, 2006 | 05:45 PM
HemiEater's Avatar
HemiEater
first page on goggle P0175
http://www.obd-codes.com/trouble_cod...gen-sensor.php
Old Dec 17, 2006 | 05:51 PM
HemiEater's Avatar
HemiEater
found this tooooo.
http://autorepair.about.com/library/...bl406a-lib.htm
my guess is the fuel pressure regulator is bad, sucking fuel in the vacuume line. Pull the vacuume line off the reg and see if it's got fuel in it.
Thats all i got......
Old Dec 17, 2006 | 06:05 PM
scottmoore's Avatar
scottmoore
Fuel pressure could be it. I will check the vacuum line. Thanks for the advice.
scott
Old Dec 17, 2006 | 07:09 PM
thefarelaneman's Avatar
thefarelaneman
my guess is the MAF sensor is telling the engine it needs more gas
F-250 restorer
27
Jul 18, 2017 07:39 PM
gibinez
1997 - 2003 F150
Nov 8, 2015 07:38 PM
Laner
6.4L Power Stroke Diesel
34
Jul 3, 2012 08:42 AM
BURNSTOUGHFORD
Feb 22, 2011 01:12 PM
Johan01
20
May 5, 2008 01:25 PM
