05 FX4 Supercrew bed squeaks
Old Dec 17, 2006 | 02:01 PM
cptslewis's Avatar
cptslewis
I have had my new truck now for over a year without any problems. It is a great truck and I love it. However I have noticed alot of squeaking coming from the bed area. I was thinking of taking off the bed and lubing the bed bushings with some synthetic grease that I used for the polyurethane bushings on the frontend of my 98 F150. I have been told that this is a large undertaking unlike the older body style f150 that I previously had. Any ideas? Is their some sort of spray that I could use? One other thing due to the fact that I live in the caribbean and live and work less then a couple hundred feet from the water I have the underneath of the truck sprayed with a corrosion ex mist that we use on the seaplanes. I dont think that this interfered with the bushings however cause it was already squeaking before that.
Old Dec 17, 2006 | 02:34 PM
WhëëlMå1's Avatar
WhëëlMå1
Are you sure it is the bed bushings? Can you recreate it by moving the bed while the truck is stationary, or do you hear it going down the road? It could be the shock bushings or even where the leaf springs mate to the frame.
Old Dec 17, 2006 | 06:28 PM
cptslewis's Avatar
cptslewis
Actually you are right I cannot get the bed to squeak while it is stationary in my driveway. How would I go about checking the shock or leaf spring bushings? I know that on a flat road it does not squeak at all. However their are probably only 5% of road surfaces on my island that are flat.
Old Dec 17, 2006 | 07:02 PM
WhëëlMå1's Avatar
WhëëlMå1
I would get some white lithium grease and lube up the eyes of the shocks, and see what that gets you. It should do the trick.
Old Dec 17, 2006 | 07:33 PM
Kizer's Avatar
Kizer
I had a bed squeak on my 06 XL 4X2 - especially on rough roads. Discovered that the fender (Driver's Side) strut located forward of the rear wheel wheel was missing a nut at the frame mounting point. The bolt was still in place just no nut.
Old Dec 18, 2006 | 05:14 AM
SRT77's Avatar
SRT77
It's probably your tailgate. Both my 98 and 05 F150 had squeeky tailgates. Put a thin layer of grease on the tailgate latches and see if that helps any.
sbraatz
Escape & Escape Hybrid
Jan 13, 2017 12:54 PM
Bonkrr
1997 - 2003 F150
Sep 14, 2009 10:19 PM
SC_Dave
Apr 28, 2008 10:54 AM
96_F150_I6_5SP
Aug 5, 2007 02:20 PM
twallace
Jul 31, 2004 09:34 AM
