Cant Fix Wiring Issue
Old Dec 16, 2006 | 11:16 PM
p_charlan's Avatar
p_charlan
-Year= 1974
-Model=F100
-2wd
-Engine= 360 2bbl
-Transmission=C6
ALL LIGHTS WOK EXCEPT THE LEFT BRAKE LAMP.
THE LEFT SIGNAL LAMP WORKS BUT NO BRAKE LIGHT.
IS THIS COMMON?
ANY ONE KNOW HOW TO FIX?
WHERE DO I GET WIRING DIAGRAM OUR LOCAL PARTS STORE DOSE NOT HAVE MANUALS. PLEASE HELP
Old Dec 16, 2006 | 11:39 PM
73f100shortbed's Avatar
73f100shortbed
I had same problem. Replacing bulb didn't help in my case. Replacing turnsignal switch did
Old Dec 16, 2006 | 11:48 PM
chopzuk's Avatar
chopzuk
try this
As you step on the brake pedal, wiggle the signal stalk and see if the brake light flashes on. If it does, your signal switch in the column probably has one of the plastic "arms" which returns it to center broken off. Will require a new switch (under the steering wheel) or some creative repair work to get it fixed.
When mine did that, I just learned to move the signal lever a little to its "sweet spot" until I had the time and money to replace the switch.
Hope this helps, Shawn
Old Dec 16, 2006 | 11:52 PM
Mil1ion's Avatar
Mil1ion
Check and/or replace the bulb.
Also, Please post in Lower case.
Posting in upper case is considered yelling and some of us won't bother trying or can't read upper case.
Welcome to the site
Old Dec 17, 2006 | 09:23 AM
fasthauler's Avatar
fasthauler
It could be something as simple as a bad ground on the left side. I have seen lights go back through the 2nd filament looking for a ground. Strange things can happen with electrical wiring. Take the tailight loose and check and clean every thing before you go too far.
Old Dec 17, 2006 | 09:26 AM
thefarelaneman's Avatar
thefarelaneman
I believe that the autozone web site has the diagram you need. With it you can trace the circuit and find the problem.
Old Dec 17, 2006 | 10:12 AM
havi's Avatar
havi
I'll have the Roast Duck
like mil1ion said, replace bulb. Cheapest fix. Second, is to look inside the bulb socket for corrosion on the brake light stem. My Bronco had this problem. Test lights, and bulbs made no difference. I was flustered. I stuck a paperclip in to each contact, and put the test light to it, and ah ha, there was my problem. The little metal strip(stem) inside the bulb holder(socket) was rusted into two pieces. The other one wasn't, which is why my turn signal worked, and my brake light didn't. So I ended up with a couple extra bulbs, no big deal. Wiring is no fun. Good luck.
Old Dec 17, 2006 | 02:13 PM
Mil1ion's Avatar
Mil1ion
The reason I mention Bulb is that sometimes the filament "looks good" but really isn't touching at one end.
The simple flick with the finger to see a filament vibrate test is a good one. However they also lose contact at the bottom of the bulb.
Always Start trouble-shooting with the obvious to take them out of the equation first.
If the other filament in the bulb works ......the problem is not the ground connection.
Old Dec 17, 2006 | 03:41 PM
p_charlan's Avatar
p_charlan
Ok i replaced bulb, checked the socket replaced the signal switch in the colum, any other ideas.
still cant find a diagram
thanks for th help
Old Dec 17, 2006 | 03:45 PM
Mil1ion's Avatar
Mil1ion
Diagram of where ? at the tail-light Turn signal switch ?
You want the Brake/TS wire colour code ?
If the right brake light works the problem isn't the brake switch.
If the Left TS light works..the problem isn't the wiring along the frame to the tail-light .
Your problem is between the brake light switch and the wire to the harness where it connects to the harness to the turn signal switch for the TS circuit.
The only online diagram is for a 76 and newer
May I suggest getting in on this super deal.
https://www.ford-trucks.com/forums/5...-rom-25-a.html
I would have to scan the 74 system.
Here is a schematic of the 78 system.
Yours is slightly different
Old Dec 17, 2006 | 05:50 PM
jimlj's Avatar
jimlj
I 2nd this. That was the problem with one of my old trucks.
Old Dec 17, 2006 | 07:45 PM
Mil1ion's Avatar
Mil1ion
The thing is..... The T/S & Brake light filament are one and the same.
The T/S light works.....it's the brake part that doesn't.
The ground is the same and is obviously okay.
Old Dec 18, 2006 | 05:40 PM
chopzuk's Avatar
chopzuk
you replaced the turn signal switch assembly?
you replaced the turn signal switch assembly? The one that is under the steering wheel? With the turn cancel mechanism built into it? Did you try the "wiggle turn signal lever, see if it flashes on with pedal applied??" Never saw a reply with results... Does the left FRONT turn signal come on and flash at a regular rate with the rear signal?
Old Dec 18, 2006 | 10:11 PM
p_charlan's Avatar
p_charlan
thanks guys i got my brake lamp to work
Apparently some thing worked? dont know what i did?
It must ahve been a combo of all the stuff.
thank you for all the help.
