5.4L bucking
Old Dec 16, 2006 | 09:59 PM
torqueyranger's Avatar
torqueyranger
5.4L bucking
My parents have a 2001 F-150 with a 5.4 and the engine will buck under heavy acceleration. However, if you feather the throttle, the problem is not apparent. The truck is not throwing any sort of code. The problem seems to be more prevalent during warmer weather and in Texas this is quite often. I know others have had issues with this bucking but a full diagnostic (performed about a year ago now) revealed nothing. I appreciate your responses in advance.
Old Dec 16, 2006 | 10:14 PM
Galveston Yankee's Avatar
Galveston Yankee
Should probably check the fuel filter and the injectors might need to be cleaned.
GY
Old Dec 16, 2006 | 10:34 PM
redford's Avatar
redford
FTE Leadership Emeritus
Also, have your catalytic converter checked. My 1995 F-150 did the same thing, some days down on power and bucking badly, other days hardly acting up at all. No codes, 5 trips to the dealer, they finally found the preconverter matrix had disintegrated and clogged the converter.
The other thing I noticed when it was acting up is the exhaust note would change, it could almost be described as a nasal note.
Old Dec 18, 2006 | 08:46 AM
torqueyranger
Thanks for your replies. We have changed the fuel filter (once) and ran injector cleaner through it several times since the problem first became apparent with no results. I'll have to look into the catalytic converter issue. The fact that the truck typically only acts up in warmer weather has always led me to believe that there may be a problem with a sensor but since no code is being given I really wouldn't know where to begin.
Old Dec 18, 2006 | 02:19 PM
redford's Avatar
redford
To check, the just unbolted the exhaust system from the Y pipe and took the truck for a (LOUD) spin around the block. The difference was dramatic.
Old Dec 18, 2006 | 06:36 PM
projectSHO89's Avatar
projectSHO89
geez....
You have a garden-variety misfire.
You need to poke around here and investigate previous misfire threads.
Steve
Old Dec 19, 2006 | 04:05 AM
LxMan1's Avatar
LxMan1
Yep, probably a coil or plug.
joshinthe586
2004 - 2008 F150
32
Jul 7, 2018 08:31 PM
Swampgrass
Modular V8 (4.6L, 5.4L)
Aug 18, 2017 11:44 AM
dewalters8886
Feb 4, 2017 10:27 PM
willystyle21
21
Nov 21, 2009 08:38 PM
FRECSF
1997 - 2003 F150
Nov 21, 2005 08:31 PM
