Help for a new 53 owner.
Question 1 It has a dodge 12 volt generator but the electrical system is 6 volt. The battery is 12 volt but all else is orignal. The truck does not shut off with the key I have to stall it. I am not bashful about wiring but i just can't figure that one out can someone please shed some light on this for me.
Question 2 Is how do i adjust the door latches/hinges the doors have new rubbers and shut very very hard.
Question 3 Who have you used for guage packages or panels.
Question 4 Besides a tilt hood what can I do for a better opening hood.
Thanks
Dan Jenkins
If you have heater or radio that are still 6V there should be voltage drop(s) for those as well.
Also, it sounds like the ignition switch is shot. NAPA and other parts stores carry a universal switch that I installed in my 48 - diagram was easy to follow.
On the doors, they are always hard to shut until the new seal looses some of its loft.
Have fun! - tim
1) Tim is probably right about the defective ignition switch. I also recommend a seperate toggle switch as a safeguard. The old engines are real easy to hotwire, so it never hurts to have another inline device to kill the power.
2) I am not familiar with the setup on the '53, but on my '50, it is possible to move the catch by loosening the bolt slightly.
3) Dolphin guages has a good looking set, but there are lots of ads in every truck magazine. Alternately, make/buy a panel and install your own guages from the local surplus shoppe.
4) Try removing the springs and soaking them in anti-sieze. Then sandblast and repaint them. I did that for mine and the hood works absolutely great.
Enjoy!
Kris Taylor
1950 F47
1977 XS650
1997 F150XL
Has any one done a full single glass replacement or an almost full glass replacement?
