Oil filter removal
Old Dec 21, 2006 | 10:18 PM
timothy47129's Avatar
timothy47129
well did you get it off?
Tim
Old Dec 23, 2006 | 10:40 AM
Troy77+79's Avatar
Troy77+79
Update
Sorry, I've been really busy doing some last minute shopping and other stuff for the past few days.
I did get the sucker off!
I bought one of the filter pliers, but I couldn't get enough room because of the PS pump, so off it came. And it still wouldn't budge. I had a good bite on it as close as I could get to the seam end of the filter, but it was just tearing in to it. So then I got the tire iron... I put the spade end right on the lip of the filter and gently pried on it hoping to loosen the seal contact a little. I guess it worked because it turned a half inch when I put the pliers back on it. But it wouldn't turn any further because of all the damage done to the filter, and the oil all over it. So then I drove the screw driver through it again, and ever so slowly got it loose enough that I could finish getting it with the pliers.
Overall, one of the slowest oil changes I've ever performed.
I'll snap a pic of the filter in a little while so you can see the carnage...
Thanks again for the help guys.
pat420swed
21
Jul 26, 2014 01:30 PM
cmmeur01
28
Mar 31, 2013 01:59 PM
hyperboarder
Jun 28, 2010 07:59 PM
RaulLopez
19
May 12, 2007 03:52 PM
dusty1
2004 - 2008 F150
19
Mar 13, 2004 04:49 PM
