Computer Chips & Tuners
Looking for advise
Old Dec 16, 2006 | 07:00 PM
maytag03's Avatar
maytag03
Question Looking for advise
I am looking for advise on buying a SCT programer. I have a 2006 250SD w/5.4 and 5 speed auto. It is also equiped with a Gear Vendors under/overdrive behind the auto, used for towing a 9000lb trailer. Have used a programer with my Ranger and was happy with the results. Since the Gear Vendors makes changes to my programming for the transmission do you think a Excalibor 2 is compatible with it? I dont want to have to dyno the truck to gain just 10-20 hp.
Old Dec 17, 2006 | 02:56 PM
ReAX's Avatar
ReAX
It will take a very good tune to get 10-20hp.
As long as the GV calibration is just to the trans file, upload it after you install a power tune. Do it that way should leave the engine parameters up to the tuner, and the trans parameters would be your tunes modified, but tweaked by GV stuff.
Old Dec 18, 2006 | 06:00 AM
BumperB's Avatar
BumperB
I have a 2006 F250 w/5.4 and 5 speed auto. I purchased custom tunes from Troyer Performance. He uses the SCT excaliber II for the tunes. Give them a call. I am sure he can hook you up. He claims up to 30 hp gains with his tunes. After you load them, he recommends datalogging to be sure the A/F ratios are good and the tune is working properly.
