What's the most sensible replacement for the original plug wires in my '49 F1 239? I'm just using the truck as a daily driver, so anything goes. Dennis Carpenter has sweet ford script plug wires, but $48.00 seems like a lot of cash for 8 wires. Advice? Thanks for reading.
Greg Kinkeade
slowtrain37(No Email Addresses In Posts!)
Your local speed shoppe should be able to set you up if you take the measurements along with you. Alternately, you could find a kit and make your own to length. If you are running 12V, then any 8mm wire should be adequate.
However, for a "sweet" custom scripted set, $6 a wire isn't unreasonable as long as the quality is there.
I bought an $18 set from WalMart for my '83 Ranger and ended up tossing them a month later when they began failing (or more appropriately, working) at random. That was a 4 cylinder, so work it out to $4.50 a wire for trash. It cost me more in down-time than a quality set of wires would have in the first place.
I would guess originally your truck might have had the old copper wire plug wires, not the resistor wire with the graphite core. My local farm store (like Farm & Family or Tractor Supply) carry these type of wire kits for farm equipment. The only thing is these will interfere with your radio if you have one.
I made mine up from a universal set. I can't remember the brand but it was normally a $50 set that I picked up for $25 on a close out. Good wires make a BIG difference. My flatty ran much better and has ever since.
