Lossing Power
Old Dec 16, 2006 | 12:49 PM
highboy390fe's Avatar
highboy390fe
Lossing Power
I have a 98 E250 5.4 auto, every once in a while while driving down the highway the van will lose all power and drop down anywhere from 5-15 mph. the only way to fix it is let go of the gas and drop the speed and then hit the gas again and everything is normal. I have no idea what to start checking can someone please help me out Thanks.
Old Dec 16, 2006 | 01:28 PM
Davetopay's Avatar
Davetopay
do you have any trouble codes?
Old Dec 18, 2006 | 09:17 AM
highboy390fe
Yes I will check them when i get home from work.
Old Dec 18, 2006 | 11:36 AM
highboy390fe
the codes that came up is P0171, P0174, P1130, what are these codes? Thanks
Old Dec 18, 2006 | 03:02 PM
highboy390fe
i found some info and fixed everything right up
Old Dec 18, 2006 | 10:17 PM
MuddyAxles's Avatar
MuddyAxles
Hey! Don't keep us in the dark!
There are many of us "silent" readers here who may have (or have had) similar problems and are interested in what you found to solve your problem.
Yer never alone here, even if we don't have a good or better answer.
So, how'd ya fix it?
Muddy
Old Dec 19, 2006 | 08:52 AM
highboy390fe
I looked up the info and it said to try check your MAF sensor, PCV valve, vacuum leaks, or possible fuel filter. So i changed the fuel filter, air cleaner, pcv valve and cleaned the MAF sensor with some brake claner and unhooked the battery for 30 minutes and it cleared the codes and they havent been back on since.
MarkNtennessee
Sep 16, 2010 08:58 AM
karljay
Nov 15, 2008 08:43 PM
bremen242
Nov 25, 2003 09:30 PM
Charlie's Truck
May 8, 2003 09:08 PM
Robert Red Ford
Jan 7, 2003 10:33 AM
