Low Voltage problem
Old Dec 16, 2006 | 08:14 AM
ChariotRun6204's Avatar
ChariotRun6204
Low Voltage problem
I only have 6.7 volts going to fuel pump. Have checked relays and grounds. Fuel pump works great if hooked to 12v direct. Why am I only getting 6.7V?
Old Dec 16, 2006 | 09:05 AM
mantta's Avatar
mantta
There is a small ground wire that goes on your negative battery post terminal, make sure it is not disconnected. If it is not connected, your pump will not work.
